Old 06-26-2007   #1
Last minute builds/changes before Proving Grounds on July 8th?
Just wondering if anyone is doing any last minute bolt-ons or full builds before the track day on July 8th? I was hoping to do a SS o2 housing, ported manifold, and test pipe, but it looks like I'll just be doing the test pipe. The o2 housings are on back-order, and since the ported manifold won't make much difference without it, I'm not going to bother swapping it in.
Old 06-26-2007   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Last minute builds/changes before Proving Grounds on July 8th?
Shit I thought it was further away. Im gonna try and get my car done for it!
Old 06-26-2007   #3
I might not make it now. Fuckin job.
Old 06-26-2007   #4
Im swapping an LS1 as i type.
Old 06-26-2007   #5
I was going to finish up my project, and tune with c16, but that's been put on hold.
-A. Swift
Old 06-26-2007   #6
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I broke all my stuff so I'm hopefully going with my buddie and his SRT-4. There's a small chanch I might have my car fixed though.
11.35 @ 120mph
Old 06-26-2007   #7
I still need to get out and tune it, been too damn busy with other stuff.
Old 06-26-2007   #8
I'm going to stop eating lunch so I weigh less.
Old 06-26-2007   #9
JET, don't forget I called you out!
Swifty, didn't you get your car tuned already? Put some gas in that thing & lets see what she does already!
Old 06-26-2007   #10
hopping to get the 50trim back and on the car sence the 61 is using about 2 quarts a week now. other wise I will be there to watch
Old 06-26-2007   #11
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
I need to get some 1000cc injectors and two turbos fabbed up with dual 4" exhaust. Oh yea, and the car delivered here and the other one gone.
'04 Honda Ricer: stock
Old 06-26-2007   #12
Correction, I WILL NOT make it now. Flying on the 8th at 7am. I'm going to stab someone.
Old 06-26-2007   #13
Last minute? HA my crank gets back from the machine shop wednesday.
We are trying to get 3 cars up and running afterhours (if this heat gives us a break) for the event.
Old 06-26-2007   #14
good luck to you fellows.
Chris, I was tuned, but the old clutch gave out on the dyno, ending my tuning session. I've got great luck with dyno-tuning. I have the new one in, but even so, I'd only be tuned on pump. Race gas won't go in till I get off and install the whole fuel system I have sitting in my room, and a JMF intake mani put on.
-A. Swift
Old 06-26-2007   #15
driftn1g
im doing an engine rebuild
Old 06-26-2007   #16
-A. Swift
So put a clutch in and run on pump gas. By the time your setup is "finalized and ready to go" oil will be long gone and your great great great great grandchild will be throwing moon rocks at your car wondering what the fuck it is.
Old 06-26-2007   #17
Cher, what are you going to put those turbos on? Come drag your evo!
Swifty, quit making excuses! Tune on pump and lets see what that thing will do! At least get some shakedown runs in!
Brandon, I'll take lots of pics for you!
Old 06-26-2007   #18
I'm putting another 150 lbs into the car to get it to full street weight! I may decide to leave out the sub and spare though, just for fun.
Also replacing the rear brakes, rear swaybar, and getting an alignment.
Old 06-26-2007   #19
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
My bike is getting the carbs synched and re-jetted and a new muffler.
Old 06-26-2007   #20
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Well I've finally done my breaks so I can stop when I get the the end of the track. And my sway bar links are in as well so I can not flip over and lose control while my rotors would have been busy sucking at life. I did a boost leak test and found 2 leaks. One was in a line and the other is my tb gasket. I replaced the line today and my fellow winoner friend gave me a tb gasket. I just baught a dsmlink cable that will work with my mac. So I can pull that battery, take out the tb, replace the gasket, and put everything back on and reload my tune. Then I'll probably still be unsatisfied and go get another tune with more boost. Shane I hope your not too busy this week!
pics or gtfo
