Old 06-18-2007   #41
Re: wish i had a 3kvr4 :(
Originally Posted by Mr.98GSX View Post
yea 50 trims are laggy, But so are every other turbo just as big or bigger. you don't see the fast dsm's runnin low and uner 12s with 16g's now do ya?! One day I'll figure out my laptop and get a good tune and learn to play with some of the features of dsmlink.
What about that guy with a FWD 1G and a 14B in the 10s?
Old 06-18-2007   #42
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
50's arent that laggy...
Then I've got a boost leak somewhere I'm hoping. We tried to do a boost leak test today, but the inlet on the 50 trim is 3inches and the rubber piece I bought when making my boost leak tester is 3.5 inches and I can't tighten it enough to stay on there past 5psi.
pics or gtfo
Old 06-18-2007   #43
HiImBrian
HiImBrian's Avatar
Find me two more people that have ran 10's with 14b's and I'll say tooshay. haha what I mean, is in general, people with bigger than 16gs do 12s'ish or better even though some people do that with smaller turbos. I'm talkin majority
pics or gtfo
Old 06-18-2007   #44
Well, make the flat part smaller, get a reducer coupler or something, because if you do the calculation (easy) you'd find that at 5 psi, it's like a 48 lb weight pushing that 3.5" flat surface out of the coupler.
Anyway, you probably don't need more than 5 psi to check for leaks anyway. Just listen and look.
Old 06-28-2007   #45
HiImBrian
HiImBrian's Avatar
Eh thought I'd bring this thread back before it's totally dead. I did a boost leak test. One line from my mbc to my turbo was pretty chewed up in one spot so that was leaking, and my tb gasket is shot. I've got a new line on and a new gasket to come. After fixing the line, the turbo is still just as laggy or even more. But I can't be too sure considering we played with the mbc a little. I'll put the new gasket in and do another boost leak test just to make sure.
pics or gtfo
Old 06-28-2007   #46
LSE Performance
What MBC are you using?
http://www.LSEPerformance.com
Ph: 763-427-9800
Email: Parts@LSEPerformance.com or Sales@LSEPerformance.com
LSE Performance is offline   Reply With Quote
