Old 06-27-2007   #1
2003eclipse
Slower than a rusty Honda
2003eclipse's Avatar
Motor Problems?!?!
Car is 03 eclipse 2.4 No mods 115k miles on it.
Its getting more and more common now, but the problem with my car is I will be accelerating and my motor does not want to rev over 4k while in gear with the gas pedal to the floor it just falls on its face like hitting the rev limiter almost. Did I spin a bearing??? Fuel not keeping up (clogged injectors weak fuel pump) I finally have money in the bank and The damn car just starts taking a shit. Its the feeling of when your clutch slips/ or hitting the rev limiter.
I LIKE TURTLES
Old 06-27-2007   #2
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
Re: Motor Problems?!?!
i had the same problem with my 95 gst when it get to 4 grand it seems like a rev limiter. i was told to get my injectors cleaned or replaced so im waiting on them right now.
justinhill is offline   Reply With Quote
Old 06-27-2007   #3
Catalytic converter plugging up?
Spun bearings make noise.
Old 06-27-2007   #4
2003eclipse
Yeah when it hits 4k it honestly sounds like the motor is going crazy. That or its just thirsty. Didn't think about the cat. I'll just bypass it. I'm hoping its something really really minor. It comes stock with two cats one 5 inches off the exhaust mani. that was honed out but another one underneath the car is in still in place. And I s'pose its been doing double time for the last 80k miles
I LIKE TURTLES
Old 06-27-2007   #5
driftn1g
INJECTORS... guarenteed
Old 06-27-2007   #6
That's money in the bank right there!
It could be a lot of different things. Do a "boost" leak test on it, to see if it is sucking in unmetered air and running lean. Have you changed plugs recently? The gap might be too big and they are flaming out. Does it have plug wires?
Old 06-27-2007   #7
Read the plugs.
Old 06-28-2007   #8
2003eclipse
WOW plugs are as white as a peice of printer paper and the gap is huge. So new plugs injectors are clogged (i'm sure) getting a new fuel filter today also.
I LIKE TURTLES
Old 06-28-2007   #9
2003eclipse
Looking around online i've found two websites that say the injectors are the same from 1990 to 06 I find that hard to believe my car runs on 450's
I LIKE TURTLES
Old 06-28-2007   #10
Why do you find that hard to believe? They've been a Mitsu favorite for years.
Old 06-28-2007   #11
2003eclipse
Just knowing they run them in a 4g63 with a turbo and here's my 3g putting out 75 horse power to the wheels N/A and running the same injectors.
I LIKE TURTLES
Old 06-29-2007   #12
iceminion
iceminion's Avatar
have nick at mitsubishi look up the part numbers
BTW, did this happen after filling up at a station that you dont commonly use? (so I can avoid it)
building a 3000GT AWD Turbo.
