Old 07-10-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Intermediate Shaft
Im trying to install the intermediate shaft on my car and Im having troubles. One of the holes lines up with a hole in the block(passanger side mounting bolt) but the other one doesnt line up with anything. I tried putting my AC bracket back it but it doesnt line up with any hole on that either. Am I missing something? I even took the shaft out and lined it up on a spare 7bolt block and its the same thing(one lines up the other doesnt). I need help ASAP!
Old 07-10-2007   #2
Re: Intermediate Shaft
The AC bracket acts as a spacer, use washers the same thickness to substitute for it. The 2 holes like up with holes in the back of the block, one is more shallow than the other one. The holes are in your AC bracket too so that you can see where they are.
Old 07-10-2007   #3
blageo23
AWD4G64
blageo23's Avatar
but it doesnt line up with the lower right corner ac hole its like 1 1/2 in to the left(driver side)
Here are some quick pics. Its against a 2g 7bolt engine but the engine thats in there looks the same.
Old 07-10-2007   #4
blageo23
AWD4G64
blageo23's Avatar
I got that axle from the kid I bought the AWD stuff. Im assuming its the correct one...
Old 07-10-2007   #5
blageo23
AWD4G64
blageo23's Avatar
Anyone?!?
Old 07-10-2007   #6
jhaan_dude
jhaan_dude's Avatar
Drives: a car
he has the damn bolt up shaft assemly on there wrong! when he probably replaced the intermedate bearing he put the thing on backwards!
Old 07-10-2007   #7
blageo23
AWD4G64
blageo23's Avatar
No its on there right(http://www.dsmtuners.com/forums/showthread.php?t=100676) Either way the bolts still dont line up
Old 07-10-2007   #8
Is there any difference in a 1g vs. a 2g intermediate shaft? He's right though, the bracket does look backwards.
Old 07-10-2007   #9
blageo23
AWD4G64
blageo23's Avatar
If you click on the link that guys looks the same as mine. I dont know if there is a difference.
Old 07-16-2007   #10
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
For some reason that looks different then the intermediate shaft I have.
Amsoil Dealer
