View Poll Results: Which system would you go with?
Apex-i N1
9 |
16.67% |
HKS Carbon Ti
3 |
5.56% |
Megan
3 |
5.56% |
Thermal
12 |
22.22% |
Buschur Racing
7 |
12.96% |
GReddy
0 |
0% |
Build your own from various available components
17 |
31.48% |
Other system
3 |
5.56% |
07-17-2007
#21
James Bond... James Bond
Drives: 95 Jeep
Re: Exhaust Opinions
Hmmm. 3.5 inch? I would like to know if there is a "real" difference between 3.0 & 3.5 inch exhaust systems?
a 3.5" pipe has about 27% (26.530612244897952%  ) more surface area than a 3" pipe...
-David C.
07-17-2007
#22
Originally Posted by DBMajik
Yeah, but then it deadens velocity.
So?
07-17-2007
#23
Originally Posted by Jakey
So?
Not that I'm as deep into fluid dynamics as you; but isn't it good to at least have some back pressure on a turbo car?
07-18-2007
#24
The turbo provides more than enough back pressure. You want as little as possible after that, it is an NA car that will need some back pressure. And velocity does nothing for the exhaust once it is out of the turbo unless you are trying to shoot it out fast to act like a jet engine and propel the car :P
07-18-2007
#25
The less exhaust after the turbo the faster it spools and the more power it makes. The best turbo exhaust is none at all.
07-18-2007
#26
OK then, custom 3.5 for me it is.
Thanks for the opinions and info.
-Mike
07-18-2007
#27
Since nobody else asked, what turbo is on the the car that you need more than a 3" exhaust?
07-18-2007
#28
deleted
07-18-2007
#29
Gt45r
07-18-2007
#30
You'll have to post some pics up when it's done! Do you plan on running a muffler? I think old man Hill's is all just straight 3.5", maybe a resonator. Pretty loud none the less!
07-18-2007
#31
It won't be as "bling-bling" as everything else 'cause I'm not crawling under there to clean it. ;-) Will have a nice muffler and tip though.
07-18-2007
#32
Why not one-up the supra and diesel truck guys?! Go 6" or go home.
#33
Well I guess I could add another tunnel down the center of the car.
07-19-2007
#34
Drives: 95 Jeep
Smoke stacks!
-David C.
07-19-2007
#35
Right Through The Power Hump!!!!!
07-23-2007
#36
OK, here's what's on the way.
Borla XR-1 race muffler 3.5 in/out
Dynomax Bullet 3.5 in/out resonators (2 of them)
3.5 inch S/S piping, bends, etc.
3.5 inch v-bands, etc, etc.
Should be fun.
07-23-2007
#37
Where'd you pick this stuff up from? What grade of SS are you going with?
07-24-2007
#38
I am sure it is 304SS, that is the main thing available. Looks like a nice setup although the 2nd resonator might be overkill. The Borla's sound damn nice, wish they were cheaper!
07-24-2007
#39
Everything is coming from Jegs. 16 gauge 304s/s piping. The resonators were pretty cheap, so I got two of them. Basically I'm going to build a duplicate of the Apex-i N1 system I have in a true free flowing 3.5 inch set-up.
07-30-2007
#40
Well the exhaust is done. 3.5 inch from the flex section back. System is almost completely straight line until it does a slight dog-leg under the rear end. There are almost no angles involved with most of the system, only slight tweaks that are way too small to even consider trying to cut and insert angled pipe. Glad I went with two resonators. I would not recommend using only one unless you want a really loud car. It's about the same volume as my old APex-i N1 system, but with a much deeper tone, almost has a Flowmaster quality to the tone at times. I'll try to get some pics posted this afternoon.
| Thread Tools |
| Display Modes |
Linear Mode
