Old 07-24-2007   #1
Bunta
Bunta's Avatar
Heat Soak?
I was wondering how is the heat soaking process of the small intercooler suppose to feel like because I'm kinda having problems with my car right now.
1990 Eagle Talon TSI AWD
Evo 3 16g
Walboro Fuel Pump 255hp
RC 550 injectors
Super AFC2
Small Side Mount Intercooler
Upper intercooler pipe with Tial BOV
K&N Filter with Dejon Intake Pipe
2g MAS
Ported 2g exhaust manifold and o2 housing
Custom 3 inch Thermal Exhaust with the 2.5 bottle neck at the o2 housing
Greddy Profec B Spec 2 boost controller
The car is tuned to RRE settings that I got off of there web page but I doubt that'll do. Sometimes when I step on it the car it just lags even though the boost guage showing boost building up. It kind of feels like when one of your injectors is bad and your car just kinda stalls when you step on it then if you kinda let it run for a bit everything kinda starts to kick back in.
I'm assuming it's because the car is running pretty rich right now because it isn't tuned and that the little intercooler just won't be able to do it's job anymore. Any inputs? boost leak?
"What you just said was the most idiotic thing i've ever heard, everyone in this room is now stupider for hearing what you just said."
Bunta is offline   Reply With Quote
Old 07-24-2007   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Heat Soak?
You need a fmic and a legitimate tune. You'll heat soak like it's going out of style on the stock smic with a 16g.
Old 07-25-2007   #3
Bunta
Bunta's Avatar
Re: Heat Soak?
So because there's been no response so far I'm assuming that it just needs a tune and a fmic.
Old 07-25-2007   #4
dedlewamp
Drives: 4G63
Re: Heat Soak?
Do you have some sort of logging device? It sounds to me like you are getting some timing pulled, causing the car to feel sluggish.
dedlewamp is offline   Reply With Quote
Old 07-25-2007   #5
Bunta
Bunta's Avatar
Re: Heat Soak?
just a afc to tune nothing else really.
Old 07-25-2007   #6
Re: Heat Soak?
Are the RRE settings for a 1G MAS or 2G MAS? It probably just needs some tuning or there might be a boost leak. It will heatsoak with that turbo and the stock sidemount though, so you don't want to go too crazy with the boost on pump gas.
Old 07-25-2007   #7
SBR_240sx
Send a message via AIM to SBR_240sx
Re: Heat Soak?
You need a FMIC !
SBR_240sx is offline   Reply With Quote
Old 07-25-2007   #8
Re: Heat Soak?
Get it tuned. I would keep the boost ~15psi to help avoid heatsoak with the tiny stock SMIC.
Old 07-25-2007   #9
Bunta
Bunta's Avatar
Re: Heat Soak?
Thanks guys!
