Old 08-03-2007   #1
iceminion
iceminion's Avatar
Galant VR4
Ok guys, this is for my 91 GVR4.
I have been saving up and doing this one right, I have the following ready to be installed:
TRE Stage2 Transmission, welded diff, taller 5th
(Switchable Transfer case w/ shifter, 2wd/4wd from the cab)
DNP T3 Mani w/Tail44 wg
SC6152s
GM Maf w/translator
Chipped ECU for the 780cc injectors
SAFC2 for fine tuning
Bar and Plate FMIC
And soon to be in my possession 280 cams with springs
Driveline mods: 4-bolt w/4WS, KYB AGXs w/ground controls, Complete ABS delete (ran all new lines, SS Flex lines, New 2-piston calipers, 5-lug converstion.
Not sure what I am going to be doing with the block, its a 2.0. I really know that I should get a 2.3 or 2.4 but thats not in the budget yet. I have been told that alot of the fun I had with my old small 16g would be gone forever due to my "large" turbo (please no comments from MAP and their Borg Warner s300).
I want to have my cake and eat it too. I want this thing to spool fast, so I was looking over NOS kits (yeah, I know its a brand, I just like saying it that way) and I am scared, I dont want to do it.
How about this: a remote mounted T25 before the muffler and after the rear diff? There would ovbiously be a cutout/dump right before the T25, probably activated by the stock wastegate actuator.
what do you think?
I am familiar with the details: remote oil and water pumps/tanks/coolers.
Will I need to isolate the turbos from each other? under low RPM boost, will the air from the T25 seep backwards through the SC61? and will the SC61 blow backwards through the T25 under high RPM boost?
thanks, and no flaming for thinking outside the box.
building a 3000GT AWD Turbo.
Old 08-03-2007   #2
Re: Galant VR4
You need to look carefully at pictures of dual turbo systems on turbodiesel pickup trucks, or maybe 3rd gen rx7's. You can plumb it so one will blow into the other and not flow backward and such, but I think you'd want something larger than a t25 in terms of flow capability, because even if you have the big turbo, the way it works is that somewhere, all the air either intake or exhaust will have to flow through at least one side of the t25 and you will be restricted.
Old 08-03-2007   #3
iceminion
iceminion's Avatar
Re: Galant VR4
I can solve the problem for the exhaust side, it will only flow through both turbos when the t25 is boosting, and when the sc61 reaches full boost the cutout will be completely open, and then the t25 will be basically not be in the equation anymore.
the only problem that I can see (for now) is that having 2 inlets to the pressurized intake side.
But thanks, ill look into the rx7s' setup
Old 08-04-2007   #4
Re: Galant VR4
You would probably want to put the smaller turbo a little closer to the engine. By the time the exhaust gets that far back, most of the velocity of the exhaust gas will be gone, plus, you'd have to pressurise all of the piping going up to the 61, so that would kill the spool time of that turbo.
Old 08-04-2007   #5
iceminion
iceminion's Avatar
Re: Galant VR4
Thanks for the feedback, I have read up alot on remote mount turbo systems, here are my thoughts:
This mod is cheap, and does not affect any of the previous mods in any way whatsoever, a slight modification to the exhaust and intake pipe is it, if it turns out to be a dismal failure, then it is a failure, but guess what, I dont think it will.
I have read up on remote turbo systems and they seem to work out great, there seems to be a great amount of what I like to call "automotive superstition" behind remote mount turbo systems, as I understand it the exhaust is leaving the engine at the same rate no matter what, there will be slight differences because of heat, the colder the exhaust gas the smaller the mass, so less air = worse spool time.
ok, so this T25 may not spool like it does on a stock 2g, I am still pretty sure that it (remote mount) will still spool faster then a 14b on a stock 1g.
I am really excited to do this, I hope to prove all of you wrong, who knows, maybe I have stumbled on to something here, because there is no way to fit 2 turbos under the hood of a 1g easily, this may change everything.
Old 08-04-2007   #6
Hoffer00
Re: Galant VR4
Let us know how it works out.
So we all can
Old 08-04-2007   #7
Re: Galant VR4
I would say just spend $300 on a 2.4 block, much easier and cheaper. Run higher compression pistons if you want better spool, those 280 cams aren't going to help either :P
Old 08-06-2007   #8
iceminion
iceminion's Avatar
Re: Galant VR4
Correct me if I am wrong, $300 on a 2.4 wont get me close to having a drivable engine.
right now I am planing on re-ringing the stock engine, and honing it out.
hopefully the motor can be put back together for around $300 (head gasket, ARPs, rings, bearings, misc gaskets)
I have always wanted a 2.4 and plan on getting one, but I cant see it happening for less then 1500 if i do it myself, and 2-3 grand if I have a shop do it correctly.
my plans for this twin turbo setup are simple and cheap, most of the supplies involved I already have, (wastegates, TBs, piping, exhaust) the only things I dont have are the turbo, and the pumps, and mini radiators.
Thanks for the intrist, and I will keep you all updated.
Old 08-06-2007   #9
Re: Galant VR4
You will need some type of cutout to open up after a certain RPM, otherwise that T25 is going to be a huge restriction in your exhaust. It is going to have to be really fast acting. Then you need some way to control it by RPM.
Maybe if you drive a tiny turbo off 1 cylinder then use the other 3 to drive a bigger one? LOL
Old 08-11-2007   #10
iceminion
iceminion's Avatar
Re: Galant VR4
Here is a diagram of what I was thinking.
this will involve a second throttle body BEFORE the GM MAF, this is to keep the SC61 isolated from the T25
the t25 inlet feed will also be before the GM MAF
so it goes Intercooler > isolator TB > T25 inlet coupler > GM MAF > Stock TB
all shutters/isolators will be controlled by wastegate actuators, so I will have like 4 boost controllers, but I dont care, I like a challenge
Old 08-11-2007   #11
Re: Galant VR4
What is going to run the 2nd throttle body?
This seems to be one of those things that is plausible on paper, but doesn't work well in real life. What happens if you are at 4k RPM and stomp on the gas where the SC61 spools quick? Also at the same boost levels for each turbo you are going to need different tunes, since the T25 is putting out much hotter air.
Old 08-11-2007   #12
Re: Galant VR4
Watch for ring land squish when reusing stock pistons.
Old 08-11-2007   #13
iceminion
iceminion's Avatar
Re: Galant VR4
Thanks for the criticism, I honestly appreciate it, no really, I want it, I hope to impress you all with my creation.
Yes, if I could have an RPM dependant acutator it might work out better.
The way I have this figured out is that the stock system is built for the SC61, the t25 is kind of the "parasite" system.
the parasite system will add to the stock system when it can (low RPMs) but since it relatively low CFM flow, I can use a one-way valve, (something like a PCV valve)
so if ever the SC61 side of the system outflows the T25 it will never backflow the parasite system, it will just close the "PCV" valve.
the second (pre) throttle body will be actuated by the boost level of the intercooler.
I hope this clears up some of the confustion created by the craziness of my idea.
Thanks
Old 08-12-2007   #14
iceminion
iceminion's Avatar
Re: Galant VR4
Goat Blower, I dont understand what ring land squish means, but I assume that the rings will expand towards the end of their stroke due to the ovaling of the 100k miles on the stock bore.
if that is what you mean, I might just spend $100 on stock pistons that are .20 over, maybe it will blow up, who cares. I would rather bore it over and use new stock pistons.
remember my power goals are about 400awhp (whatever that means) which I have heard can be done on stock internals.
I WILL be building a forged motor eventually, but now is a time to have fun.
thanks, and I am gland that I am now 23 and I am totally drunk, my birthday is the 12th, you guys rock!
Old 08-12-2007   #15
Re: Galant VR4
I am not trying to discourage you, just trying to help you think things through so you don't run into any unexpected problems.
So the 2nd TB is going to be dependant on boost pressure, but what actually opens and closes it? Now that I think about it more, a simple flapper valve installed in a reverse Y might do the same thing and need no other mechanicals. Whichever side is flowing more is going to push the valve open more.
I can see quite a few pitfalls to this system and it will obviously not make the power it would without it on, because of all the restriction that will be added by valves, the extra turbo (with TINY exhaust side) and such. You would probably be better off to just go with a centrifigal supercharger or a 50 trim
Old 08-12-2007   #16
iceminion
iceminion's Avatar
Re: Galant VR4
I was hoping on having a wastegate actuator open the TB, I know that there is only about an inch of travel from the wastegate, so it will be tricky to make the TB open all the way.
A Y pipe may work out a little better.
The tiny exhaust side of the T25 will only be in play under low boost, I will have a cutout in front of the T25 so under high boost/RPM all the air will bypass the T25 completely.
Old 10-11-2007   #17
Re: Galant VR4
Any update on this twin-turbo setup?
Old 10-11-2007   #18
twack
It was a auto get over it
twack's Avatar
Re: Galant VR4
Wow i dont know how i missed this thread, sounds interesting. Seems like every once in awhile these threads pop up they try the system out for awhile either scrap it or are never to be heard from again
Old 10-21-2007   #19
AlexNGreen
Re: Galant VR4
Alex, just go with the nitrous. The big turbo 2.4l ford guys run it for a few seconds and then turn it off. Do small jets just to get things hot you'll be fine. It'll be cheaper than all this extra turbo crap and it'll help save money for the stroker. Then you'll also have an extra nitrous kit around. So its Win Win .
AlexNGreen is offline   Reply With Quote
Old 11-07-2007   #20
iceminion
iceminion's Avatar
Re: Galant VR4
Well sorry to disappoint with the twin-turbo setup, but I am staying single turbo for now.
I drove the car last night, almost cooked the engine, I had the engine revving with no oil leaks so I took it for a spin, bad move.
the aftermarket oil pressure sender unit started leaking and I lost 2 qts of oil (nothing on dip stik, I added 4 and now I am 2 over, so its all good)
The GVR4 never had an oil pressure gauge stock, only the red warning light.
So here is the car now for power:
-2.3 stroker with mahle 9.5:1 pistons - Modern Automotive Performance
-BC280 cams with ti springs, rev limit currently at 8k,
-SC61
-DNP T3 Mani w/tial44
-chipped for 780cc
Other things:
-2wd/4wd switchable t-case
-TRE stege2 /welded diff/taller 5th
-Jet setup my intercooler pips a while back, still using them, might have to get a different BOV as I go 20+ psi
-Audi 5000 CS (5kqt) Radiator (24" x 12" x 2") this is a thick son-of-a-bitch that fits perfectly where the AC condenser used to be, I could go on and on about how superior this radiator is to the shitty DSM radiators that are on the market now,
-external oil cooler - Modern Automotive Performance
-adjustable cam gears! whoohoo! 1000+AWHP!!!!
So much for never hearing from me again. I sooooooooooo want to do the second turbo just to shove it in the nay-sayers faces! (good job guys for making me go 2.3, its just a whole lot easier then my crazy f-cking ideas)
ID:	6563   Click image for larger version
