Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 08-14-2007   #561
Re: Finally getting stuff done on our cars
That I am, looking for a small civic size just to help reduce weight.
Pushit2.0 is offline
Old 08-14-2007   #562
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Wow John...get her done man.... That looks freaking sweet.
Josh LaCroix
92EvilTalon is offline
Old 08-14-2007   #563
I may have a stock Honda radiator. Unless your looking for an after market Honda sized one?
Speedfreak is offline
Old 08-14-2007   #564
Damn. That looks very nice
Kevin 1G Drummer is offline
Old 08-14-2007   #565
Very nice, John!
JET is offline
Old 08-14-2007   #566
Yeah, those wiring harnesses can be a bitch, but it's lookin' good. Nice AIT sensor location. (are you using multiple aits's?).
FattyBoomBatty is offline
Old 08-15-2007   #567
Just the one for now. The few little things to finish: mount the radiator and make coolant hoses, run the oil feed and drain for the turbo, run the water lines for the water to air, tin around the fuel cell and trunk, run the battery wires, finish the interior wires(gauges and the alternator/fuse box, run a few switches for fans and the water pump, clean out and tighten fittings in the fuel system, finish mount the fuel pump, load base map break in car and tune, so not that much. I am also looking into removing the sun roof, gutting all the doors and putting in lexan windows, and a carbon fiber hood would be cool but not until next year.
Old 08-15-2007   #568
Saw the car on Saturday, looking good!
Jakey is offline
Old 08-15-2007   #569
Make sure to run 19's for daily use.
Old 08-16-2007   #570
hahaha yea! You should pick up those bling rims that SGH had for sale :P
scheides is offline
Old 08-16-2007   #571
I think a set of Weld wheels(or similar, light) and full slicks will be in order befor it sees the track.
Old 10-05-2007   #572
I have a little more done on the car, radiator and hoses are almost done, the wiring is almost done, and I decided to remove the dash and make a custom gauge cluster. I have cut down the alternator harness to where I need it, now its time to run the wires for it. I hope to have it at the fall dyno day. The car will be tuned on E85 or c-16, it depends when MN switchs to the winter mix.
Old 10-05-2007   #573
Bah, use E98, much cheaper and the blend is consistent.
Good to see you're keeping it and getting her done.
Goat Blower is offline
Old 10-05-2007   #574
^second that, keep it buddy, its cool that you have had that car since HS, don't give it up and if you ever need a hand after hours let me know.
turbotalon1g is offline
Old 10-05-2007   #575
Lies.
C-16 noob.
niterydr is offline
Old 10-05-2007   #576
I am running on hopes and dreams, and I might have to push it across the line.
Old 10-05-2007   #577
not was a 2jz no shyt!!!
-A. Swift
Swifty1638 is offline
Old 10-05-2007   #578
"after 10, 15 grand tops, over night parts from Japan if we have to, it will desimate all." "I need 2 big bottles, and I need it by tonight", the only time in the hole move they referd to it has Nitrous Oxide, not nawwwzzzz.
Old 10-05-2007   #579
Shouldn't you guys be working somewhere?
(I am on hold transfering a call!).
niterydr is offline
Old 10-05-2007   #580
Nope. I jsut got back from the shop. Thanks john! I think every issue is fixed! It pulls, shifts through the gears when I pound them, doesn't die on me..etc. Too bad the end of the year is here, and If I tuned it would be a waste. So, I'll wait till I get those parts we talked about onto my car, then tune. I think this time around the clutch will hold, and the car will rev out!
-A. Swift
Closed Thread
