Old 08-16-2007   #1
Joefluff
Can you repair a carbon fiber hood?
I have a Carbon fiber hood and got hit in the front end. I got everything fixed but my carbon fiber hood is "spidering" or has cracks in the surface. there is no other damage done to the hood. I herd if you take clear coat and buff it that the cracks disapear. Is that true? if not is there any other way to fix it?
Joefluff is offline   Reply With Quote
Old 08-16-2007   #2
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: Can you repair a carbon fiber hood?
it sounds e'ffed man
Old 08-16-2007   #3
x-pride
x-pride's Avatar
A body shop will be able to repair it. You might have to repaint it though. Best is to call up a body shop and ask.
Old 08-16-2007   #4
ExTREME
ExTREME's Avatar
Here's a video on how to fix your hood man.
Hope it works out for you!
Click Me
Old 08-16-2007   #5
Repairing carbon fiber is a very tricky thing. If the cracks go down to the mesh, (which they probably do) The hood is fucked, and it can't be repaired. If the cracks aren't deep enough to go into the mesh, they can be sanded out, then re-clearcoated. If you end up sanding intop the mesh, it tears it all up, and it's impossible to fix and not be noticable.
Old 08-16-2007   #6
kennydawgg
+1 on what kevin said its probably possiblle to have a body guy put a thin layer of bondo and paint it to match your car but you would loose the look. and it would probably cost 300-500 to do. possibility though
kennydawgg is offline   Reply With Quote
