Old 08-18-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
aahh code p1104 this is making me mad
so i been having a little trouble with the car and with the check engine light on throwing the code p1104 witch i know is the waste gate solenoid so i final went and looked for the problem when i went down there by the filter the sensor wires and the suckion nipples where cut off is there anyway i can not use this sensor or what?
justinhill is offline   Reply With Quote
Old 08-18-2007   #2
Re: aahh code p1104 this is making me mad
It only matters that its plugged in; it doesn't have to be hooked up to any hoses or doing what it was designed to do. If it is plugged in, you might need to swap it out for a different one to eliminate the code.
Old 08-18-2007   #3
blageo23
AWD4G64
blageo23's Avatar
I think I have one here somewhere if you need one
Old 08-30-2007   #4
Project2G
Semper Fidelis
Project2G's Avatar
Drives: 1997 Eclipse GST
I just had this same problem but my code was P1103. I had mine plugged in and for whatever reason it was throwing a code and I would hit fuel cut when boosting more then 11psi. I put on Toms and the problem went away and now I'm boosting 16psi on my T28.
