Go Back   MitsuStyle > The Homefront! > Everything Racing
Old 09-07-2007   #21
Re: Rock Falls Sat. Sept 22
well i am going, i just need an overflow and i am gonna order that monday at the latest.
also i am quitting my job, soon slave labor is something Big brown does not stand for.
Old 09-07-2007   #22
Dude, you were my tire hookup though, RAHHH!!! This sounds kinda fun though. I'd need to find a helmet if I went. Is there still some sorta rule about not being allowed to have any sort of electronics (IE laptop) while you run, making it impossible to log?
Old 09-07-2007   #23
I have never had an issue with having the laptop in the passenger's seat.
Old 09-07-2007   #24
Have you gone this year though? I thought it was something new they were bringing up this year.
Old 09-07-2007   #25
I've seen a few pics of cars having a shelf under the pass seat with a slide bar or something that locks in the laptop. Works pretty slick and seems like it would be easy enough to make.
Old 09-07-2007   #26
you can use my helmet, my two brothers still work there, and chris is paid hourly which is better than 8.50/hr with a minimum 55 hours a week.
computer stuff they don't care unless its a special race, just turn on the log before you go thru the water box and you will be fine.
Old 09-08-2007   #27
Shit, no water box for me. You working tomorrow? I'll finish powdering your shit tomorrow. And if you come get it, bring your helmet so I can try it on for fit.
Old 09-08-2007   #28
word son^. gimme a call.
Old 09-08-2007   #29
My tires will be here next week so I'll be following up the rear in the Evo.
Old 09-08-2007   #30
Wow, that's the most comprehensible drunk post I've ever done! Man I have a headache.
Old 09-08-2007   #31
haha! me too man. I don't think i've ever seen that much skin of yours before!
-A. Swift
Old 09-08-2007   #32
I have a spacer here that I use to dig threw my bolt tray, let me know if you need it.
Old 09-08-2007   #33
huh?
-A. Swift
Old 09-08-2007   #34
Actually the twin disks aren't aluminum flywheels. I have the Devo one Steve, so it should be a PTT flywheel. I was thinking the same thing John, if they loosen up one more time I will tack weld the bolts to the spacer from the auto, then I can grind the tacks off and not damage the flywheel itself.
I'm about 90% mine is, I'll have to look at the pictures.
Was your crank turned by chance?
Old 09-08-2007   #35
Nope, stock crank. I don't there is a surface plate bolted on like a fidanza, is there? I am almost positive it is chromoly. Here is a pic and I don't see anything bolted on.
Old 09-08-2007   #36
b00stcreep21
I hate everyone
b00stcreep21's Avatar
-A. Swift
No one else found this statment awkward?
Old 09-08-2007   #37
I was showing my bewbs to a girl in a 2g (and I mooned her), and Swifty decided he wanted to peek over and see too. Not my fault.
Old 09-08-2007   #38
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Jet do you have the Alignment pin in the end of the crank? most 2.4 cranks came out of auto car without the alignment pin. Just another thought.
11.35 @ 120mph
Old 09-09-2007   #39
I couldn't help but notice brandon. You are the whitest person I know. Get some sun man! Even Emily isn't that white!
-A. Swift
Old 09-09-2007   #40
x-pride
x-pride's Avatar
-A. Swift
Little to much info here. I will never look at Brandon the same way again. Dam you Swifty dam you!
