Old 09-13-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Fuel Leaking
If I have my hood open you can smell fuel. Also when you turn the car off the fuel pressure goes down to zero(sometimes taking a min but usually goes straight down). Is there a dye you can put in the fuel to find a leak(like what they have for coolant, oil and refrigerent)? I have AN lines from tank back to tank. and there is no leak that I can see.
Old 09-13-2007   #2
Re: Fuel Leaking
Are you sure the car isn't a conquest? j/k. Why don't you put a white paper towel under each injector and each connection joint for the AN lines? That's a good way to narrow it down.
Old 09-13-2007   #3
blageo23
AWD4G64
blageo23's Avatar
Re: Fuel Leaking
Hmm, thats a good Idea, Never thought of that. Ill give that a try.
Old 09-13-2007   #4
Re: Fuel Leaking
SS lines have problems with fume leakage and not holding pressure after the car is off isn't a problem.
Old 09-13-2007   #5
Re: Fuel Leaking
You can feel around for leaks too. I would check the ends of the fuel rail. Did you use new o-rings?
Old 09-13-2007   #6
Re: Fuel Leaking
He has TIGed on Earls fittings on the stock rail.
Old 09-13-2007   #7
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: Fuel Leaking
I'd start around the injectors. Make sure the top o-ring isn't leaking. Like fatty said, paper towels work well. Otherwise, just take a flashlight and look for wetness on the injectors, and around your fittings. That is IF you actually do have a leak
Old 09-14-2007   #8
Re: Fuel Leaking
I would use a lighter or a match around each fitting and see which fittings start a flash fire, just make sure to take out your Nawwzzzzzz tanks first though.
I would look at the welded fittings or injectors for leaks. The fuel rails are nasty dirty cast aluminum which is hard to weld to.
Old 09-14-2007   #9
blageo23
AWD4G64
blageo23's Avatar
Re: Fuel Leaking
MA welded it for me and then It was powder coated. I dont see any leaks around where it was welded
Old 09-14-2007   #10
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Fuel Leaking
Maybe check where the fuel filter is. I have alot of troubles keeping that from leaking on me.
Amsoil Dealer
Old 09-14-2007   #11
blageo23
AWD4G64
blageo23's Avatar
Re: Fuel Leaking
Pshh, you kids and you STOCK fuel filters
Old 09-15-2007   #12
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Fuel Leaking
Ha ha ha ya thats right you are too cool for stock parts like that.
Amsoil Dealer
