Old 10-04-2007   #21
Re: Evo X
I would like to see how strong the motor / clutch / tranny / fuel system / intercooler / etc are compared to what we are used to. So to find the limit we buy one and bolt a GT47 on there and start breaking stuff. Open deck motors ftw.
Old 10-04-2007   #22
Re: Evo X
It is not an open deck motor, they modified the 4B11 for the turbo, it is now a semi-closed deck. It is also nice to see that a manual X GSR is only 60 lbs heavier than a IX MR.
Old 10-04-2007   #23
Re: Evo X
What does open deck or semi-open deck mean anyways?
Old 10-04-2007   #24
Re: Evo X
Open deck means the cylinders have one big coolant passage all the way around the deck and it is not supported. 4g63 is a closed deck, with just the coolant passages open. A semi-closed deck will have supports going from the cylinder to the block, but still fairly open. It should be fine for high HP though from that aspect. That is why the Honda guys put a block guard in, like so:
That turns an open deck into a semi closed deck, the 4B11T will come with something like that installed from the factory.
Old 10-04-2007   #25
Re: Evo X
Just search for pics of STi, Honda, and 4G63 short blocks. The 4G63 has a fully closed deck. Most Honda engines like a GSR(B18C1), D16, NSX, Type-R, later H22s, etc have an open deck block. To make decent power with the Honda engines, you need to sleeve the blocks, which usually involves totally boring out the stock sleeves and replacing them with a supported sleeve or one close to a semi-closed deck. The STi has a semi-closed deck design, which lets them handle some power compared to the WRX that has an open deck design and is a fairly weak motor.
Old 10-04-2007   #26
Re: Evo X
The Honda guys stopped using block guards a while ago. They usually only made things worse, since putting them in distorted the cylinder placement and the sleeves often cracked at the bottom anyways. You can get farther on the stock Honda sleeves than people used to think 5 years ago, but if you want to run big boost reliabily you need to sleeve it or buy a closed deck Dat Honda block.
Old 10-04-2007   #27
Re: Evo X
Thank you for the awesome answers guys!
Old 10-04-2007   #28
Re: Evo X
pictures from Do-Luck this morning of the Evo 10 that they have in colloboration with ARC.
Parts for the car are already under development by both Do-Luck and ARC and they expect to showcase the car very soon, more than likely at the Tokyo Auto Salon.
Safe to say Do-Luck is continuing its development with Evo's with products expected to be released shortly for the Evo 10, we'll before UK cars arrive even, which is great news.
We can expect to see some Aero parts as well as strengthening , and cooling parts of course such as intercoolers and radiators etc.
Picture of a Ti exhaust in planning
Old 10-04-2007   #29
Re: Evo X
How do you know that?...
I am not sure, I think the automotive industry will be looking at ways to over engineer cars less and less, that way it costs them less, thats all I am getting at.
Old 10-05-2007   #30
Re: Evo X
Rally Evo X
Old 10-05-2007   #31
Re: Evo X
I like the fact they have gone to a timing chain, and have eliminated the balance shafts.
Old 10-05-2007   #32
Re: Evo X
Yup, 2 steps in the right direction.
Old 10-07-2007   #33
Re: Evo X
Holy shit, white is HOOOTTT!!!
Here is a black one for ya Scheides.
Old 10-07-2007   #34
Re: Evo X
White is hot!
Old 10-07-2007   #35
Re: Evo X
That back end is going to look HOT with dual 4" tips hanging out of it
I dunno....I think its growing on me
Old 10-07-2007   #36
Re: Evo X
White is hot!
No doubt, I have never had a white car that I cared about, but this may change it. I have always went with black or silver. A white MR with tinted windows may be in my future when I sell this house!
Old 10-07-2007   #37
Re: Evo X
I'm kinda disappointed with this car in terms of styling. I'm curious to see how the engine handles more power.
Old 10-07-2007   #38
Re: Evo X
I like the addition of factory foglights.
Old 10-07-2007   #39
Re: Evo X
My car has fog lights! Just for the 7,8, and 9 they were integrated into the main headlight array. I like having separate fog lights though, looks cooler IMHO (a-la the HUGE ones on an Evo6).
Old 10-07-2007   #40
Re: Evo X
Just to let people know, the white one is a GSR. It has black vents on it (hood and behind front wheels) and MR's have body color vents. The MR has better wheels, brakes and suspension, but the white GSR has the performance package to get the same ones. The MR also gets the silver grille and little chrome piece around the grille. MR also gets an upgraded interior and SST (think DSG with better tuning and options).
