Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 10-19-2007   #641
Re: Finally getting stuff done on our cars
this thing is so fucking loud. It is hard to work in the shop even with ear muffs on. But is fucking bad ass
TkrPerformance is offline
Old 10-19-2007   #642
Clutch slip owns, guess we have a good fuse for the track.
Plenty of power left on tap, but we tapped out the clutch right away.
niterydr is offline
Old 10-19-2007   #643
Congrat! But, I told you not to put the ACT 2100 in there.
Shane@DBPerformance is offline
Old 10-19-2007   #644
Wow, that thing is going to be a handful! Is any of the short powerband due to the clutch slipping? Nice numbers, it should be a lot of fun to drive.
JET is offline
Old 10-19-2007   #645
Yeah the clutch slips the more we turn it up, its like a torque converter
John just hit it on the street, LMAO. 1-2 shift car got about 45 degrees sideways @9k in 1st gear. The car unloads even with a 140 ramp rate, we didn't bother to try higher.
We will leave the power where it is at for now and just sort out the rest of the car for spring, see you all tommorrow.
It could make more tommorrow if the clutch is broken in, we'll see.
niterydr is offline
Old 10-19-2007   #646
So much for breaking in the clutch!
scheides is offline
Old 10-19-2007   #647
EVOMR05
Mommy
even in the office it was load...had to tell a customer to hold on cuz couldn't here him on the phone!
~ Mom ~
EVOMR05 is offline
Old 10-19-2007   #648
Eh thats stuff you tell customers.
It'll break in over time.
niterydr is offline
Old 10-19-2007   #649
By unload, do you mean the clutch slipping? What was the boost at?
Why does it need break-in? I wouldn't think he would have an organic disc in there.
Old 10-19-2007   #650
Its a 6 puck FE disk, it might wear in a little.
Boost was at 36, but spikes higher in the beginning.
Last edited by Pushit2.0; 10-20-2007 at 10:47 AM.. Reason: edit on clutch type, it happens
niterydr is offline
Old 10-20-2007   #651
The track will be a good place to finish tune the car, and if the clutch still does not work I will find a 3200lb PP and if that does not work then I save up for a Tiltan triple disk or something. Yes we ment the clutch is slipping, the tires are not spinning on the dyno atleast. It nice to shift and be right back on peek torque though, this should be a fun car on slicks at the track. I thought about going to the track sunday, but I do not need to see what my track time would be while doing a few 360s.
Pushit2.0 is offline
Old 10-20-2007   #652
sweet
FattyBoomBatty is offline
Old 10-20-2007   #653
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
wowza. Very nice work yet again!
Tyler Aherns
-USN-
98gstaherns is offline
Old 10-24-2007   #654
Who wants to loan me some tires for the track this weekend?
Old 10-24-2007   #655
You missed out, I sold an ACT 3200 PP for $75 not too long ago.
Goat Blower is offline
Old 10-24-2007   #656
I want to see if its a problem on the track first, SBC also sujested the disk will have to wear itself into the flywheel and PP, this might take a little time, we will see.
Old 10-24-2007   #657
Do they have some puck disc that requires no breakin at all that you can just throw in? I find it strange that is slipping with the torque that your car is making, my wifes old 2600 holds over 400ft-lbs at the wheels on the dyno without slipping.
Old 10-24-2007   #658
My 2600 has held 490wtq(on my Dynojet) and at the track. It did smell a bit after each run at Cedar falls, but no obvious slipping down the track. The same clutch is still in the car two years later.
Speedfreak is offline
Old 10-24-2007   #659
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Glad to hear is finally running
I got 2 slicks if you can find someone to lend you another set that matches. I think there 23 inch but Id have to check.
11.35 @ 120mph
carltalon is offline
Old 10-24-2007   #660
Just air down the ones you have. Light 'em up if you can, bitches.
Closed Thread
