10-22-2007
#1
wants to kick mark
Drives: Battery with wheels
finally getting the car tuned
After 3 or so years of fixing , rebuilding and replacing it is time to actually tune the car. So #'s will be posted tomorrow after i get back from LSE, even though it'll only be on pump gas then re-tune w/ e-85 once spring hits and i get the rest of the fuel system in place.
so for those who asked here is the list of whats done
block bored 40 over
weisco pistons
eagle rods
balanced
ported and polished head
ss valves
bronze guides
bc 280 cams
crower single valve springs
titanium retainers
1mm lifters
fidanza adj cam gears
twin in-tank walbro 255 pumps
pte 1600cc injectors
aeromotive adj fpr
high flow fuel rail-not sure on brand
turbonetics t3 exhaust manifold
tial 38mm gate
gt3561 turbo w/ ar 82 exhaust housing
xs power front mount-go ebay
dejon tool upper pipe w/ gm maf
tial 50mm bov
tre stage 2 tranny w/ welded diff
act 2600 clutch and flywheel w/ fidanza friction disk
home made 3in exhaust
dsm link
thats basically it for power stuff
of course brakes and suspension have been upgraded
10-23-2007
#2
wants to kick mark
Re: finally getting the car tuned
so i lied i went ahead and put my 1600cc injectors in and did a fall tune on my car on e85. put down a good number but the boost will be turned up in the summer once the blend gets put back to normal. So this is at 22psi spike to 24psi
10-23-2007
#3
very nice what mods done?
10-23-2007
#4
Very nice numbers Craig!
10-23-2007
#5
wants to kick mark
gt3561 turbo, ported head bc 280 cam. springs and retainers. weisco pistons and eagle rods, bunch o other stuff that goes along those lines. good part is w/ the dual 255 pumps the stock line seems to be holding up so i can go get some cash back for the an line i have.
10-23-2007
#6
craig was up here you a good part of the day and I got me some free gas out of the deal when I drained my bro's tank about 9 gal's of 92 bp.
I know you were realy happy with the numbers when you were thing around 350 or so. wait till summer blend and 28-30 psi to come
10-23-2007
#7
Damn...nice!
Originally Posted by Murlo26
#8
Nice numbers Craig. I've got my AN line kit here on the workbench as well. Stockish size lines and dual pumps work just fine, so far.
10-23-2007
#9
wants to kick mark
yeah thats what i thought too, thanks as well
10-23-2007
#10
Good power Craig!
10-23-2007
#11
wants to kick mark
oh yeah and of course the crappy act 2600 was slipping as well according to john
10-23-2007
#12
Nice numbers man! What rpm are those tq and whp peaks at?
10-23-2007
#13
wants to kick mark
i cant remember exactly but i think its like 7200 or something idk i'd have to ask john
10-24-2007
#14
Peak Tq: 349.0 @ 6000 rpm
Peak Hp: 408.3 @ 6400 rpm
The clutch might be a problem in spring with a summer blend and a MBC, but it seems fine for now, it slips a little but I have seen worse.
10-24-2007
#15
I think SA is the only one who uses a summer/winter blend, i called holiday and they said they run 85% yeah around, it also says on the pumps at SA 70%minimum and at holiday 85% minimum.
Congrats looks like a fun ride.
10-24-2007
#16
Nice numbers!!!
10-24-2007
#17
There is supposed to be 4 changes in E85 in this area throughout the year. Summer blend is June, July, and August. Merkzu has an alcohol mixture gauge in his car and had something like 81% ethanol on the dyno day from a Kwik Trip near his house, he from the Holiday's near his house he was getting something like only 70% ethanol.
10-24-2007
#18
Craig, do you have a chart with boost and RPM? What cams and intake manifold?
10-24-2007
#19
well i finally called up SA n Holiday and told me that they have switched to E70
10-24-2007
#20
wants to kick mark
no chart on the boost and rpm unless john has one saved somewhere. as for cams they're bc 280's and a stock intake manifold
| Thread Tools |
| Display Modes |
Linear Mode
