Old 10-24-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Which cams?
This is going on my car...
Built 2.4l
Stock Head
Magnus intake mani
20G turbo
FMIC
(that should be all you need to know)
Im thinking about going with HKS 280 cams. Is there any other cams that would be good for my car? Also what are the pros and cons of the cams you suggest. Will I need springs and retainers for them? Thanks in advance.
Mike
Old 10-24-2007   #2
Re: Which cams?
HKS is always one of the best cam choices for a DSM, and their 280-grind should work well on a 2.4.
Old 10-24-2007   #3
Re: Which cams?
Man there are so many cams out nowadays. FP sells some stroker specific grinds, some of which require stiffer springs.
BC sells some giant 288s but they are over .450 lift so you may need some non-stock valve seals to clear that.
HKS is good, and their centerlines always seem to be right where they should so they dont NEED to be degreed.
Old 10-24-2007   #4
Re: Which cams?
I don't know shit about how to truly spec a set of cams for a car, however, it doesn't take much reading across various forums to learn that with all these cams out there, the spring and retainer choice is absolutely critical.
Old 10-24-2007   #5
Re: Which cams?
Spring and retainer choice is overrated on a 2.4, if you aren't going much over 8k rpm. I run crower single springs on my crower 415's with well over .500" of lift without a problem. I would say 280's are the minimum you should go. If you plan on going to a bigger turbo any time, then I would go bigger. I would probably look at the FP3 cams or BC 288's. Big cams for a 2.0 become much more mild in a 2.4.
Old 10-25-2007   #6
blageo23
AWD4G64
blageo23's Avatar
Re: Which cams?
Are BC cams any good? I swear I heard bad things about them.
Old 10-25-2007   #7
Re: Which cams?
Crower 415: 288/288 advertised duration; 0.425"/0.416" lift;
BC 288: 288/288 ; 0.468"/0.478"
stock 248/248 ; 0.349"/0.350"
HKS 280 280/280 0.425/0.401
FP cams w/cards
Take those with a grain of salt, Some of those figures are multiplied by the rocker ratio and some probably are not. Keep in mind lift and overall duration are just the beginning when you really start looking into cams.
Old 10-25-2007   #8
Re: Which cams?
Just thought i'd throw this in cause its interesting.
Stock S2000 (F20C) cam
Dur
300°/298°
Dur@.05"
226°/222°
Lift (in)
.498"/.459"
woot time to sneak into hughes garage and steal some cams!
Old 10-25-2007   #9
Wizard
Re: Which cams?
That cam spec for the S2000 is after the VTEC solenoids have activated...
Remember, VTEC cams are in a sense....2 cams in one.
Personally, HKS have always been the cams to have. But, people have found others that are just as good if not better and cheaper.
BC cams have been fairly recent additions and seem to be everyone's fav at the moment with great power, and nothing but good things to say.
Crower (Not Brian Crower aka BC) need to stick to making NA cams as they have no idea how to make power in a turbo DSM. Not to mention lots of bad things about them like breaking. Sorry, but NO new cam should break.
Web was pretty good until they had a bad batch go thru and everyone stopped using them. They are still a good company imo.
FP cams use specs similar to the HKS and Crower grinds but offer several tweaks to make them more 'streetable' or basically more choices to get a grind that more matches your build.
There are a few others like Reed and such. But...my vote is BC, FP or HKS and at least a 272 grind, with 280 as a recc. And anything over 264 grind you will need spring/retainer upgrade. Not from the revs or rpms...but the lift of the cams will cause stock springs to bind.
Wiz
Old 10-25-2007   #10
Re: Which cams?
Originally Posted by Wizard View Post
Crower (Not Brian Crower aka BC) need to stick to making NA cams as they have no idea how to make power in a turbo DSM. Wiz
Crap, someone should have told my car it couldn't make any power because it has bad cams. I guess John's Galant doesn't make any power either.
On the 415's, I know my cam card is WAY bigger than what they advertised. John has the same cams and they did also. Do you remember what they were John? I have the card around somewhere, but the computer with the pic on crashed, so I don't have it and DSMStyle has been dumped since I posted it.
Old 10-25-2007   #11
Re: Which cams?
Damn, that is some lift for a DSM cam. I am surprised it will supposedly work with the BC single springs. Usually over .425" you have to worry about the valve guides.
Old 10-25-2007   #12
Re: Which cams?
HKS 264s and 272s have the exact same lift. 9.8mm exh 10.2mm int
Im not so sure stiffer springs are required for HKS 280s either. At least i cant find any literature with them specifically saying YOU NEED SPRINGS TO RUN THIS CAM.
Old 10-25-2007   #13
Wizard
Re: Which cams?
Part # Description Duration @ .050" Gross Lift w/1.7
STOCK Stock Turbo Cam 174 / 165 .366" / .343"
HKS264 HKS 264 187 / 186 .392"/.374"
HKS272 HKS 272 195 / 195 .399"/.379"
546/547 Web Cams 206 / 206 .400"/.385"
I also found supposedly the actual spec cards from HKS:
264 Intake
Max Valve Lift - 10.3mm (0.4055")
Centerline at 0mm vavle lift 105 deg
Intake Valve timing at 1mm (0.0394")
Valve opens at 2 deg BTDC
Valve closes at 28 deg ABDC
Valve Centerline 105 deg (WRONG - 103 deg)
264 Exhaust
Max Valve Lift - 9.8mm (0.3858")
Centerline at 0mm vavle lift 117 deg
Exhaust Valve timing at 1mm (0.0394")
Valve opens at 42 deg BBDC
Valve closes at -12 deg ATDC
Valve Centerline 117 deg (CORRECT)
272 Intake
Valve opens at 6 deg BTDC
Valve closes at 32 deg ABDC
272 Exhaust
Centerline at 0mm vavle lift 111 deg
Valve opens at 36 deg BBDC
Vavle closes at 2 deg ATDC
Vavle Centerline 111 deg (WRONG - 107 deg)
I cant find any stock valve spring coil bind limit, but guessing it would be around .450". And it would be a nice safe bet the the measly $200 on a basic upgrade springs/retainers would give you insurance. Not to mention, the stock springs are not new and their numbers have surely faded over time. IE: Weaker and more prone to break or bind. Bad time find to this out is after you put your multi$$$k motor together and first good pull over 6k and a valve fails to close in time.
Just upgrade and you'll be safe.
Wiz
Old 10-25-2007   #14
Re: Which cams?
How would an old spring be more succeptible to binding? Just because you wouldn't do it, doesn't mean it is necessary. The stereotypes for the cam companies are off also. Nothing against you Wiz, but you always come on here stating your opinions as hard fact and everyone should do what you say. You are far from a DSM guru and your opinions are not fact.
Old 10-25-2007   #15
Re: Which cams?
I also run the Crower 415s, I use our single valve springs, same specs as a Crower spring, ~50lbs seat pressure and ~170ish at .4" lift. I put in some .040" shims under my springs to get the pressure up to the 210lbs @.435 lift that the cam card says it needs. I also shaved down the weight of my retainers a few grams to help at high RPM. My cams showed just under the advertised lift at the valve, I think it was .435" (.438") on the intake and .425" (.429") on the exhaust side. But the duration from .05" was 6 deg longer on the intake and 4 deg on the exhaust side. I am happy with my cam/spring/retainer combo they are holding up fine and making good power all the way to 9500rpm. Also Crower springs will coil bind around .955" over all height and be around 260lbs, I think mine are around 1.095" at max lift on the intake side right now.
Old 10-25-2007   #16
Re: Which cams?
Just buy my HKS 280s and be done with it.
Old 10-25-2007   #17
Wizard
Re: Which cams?
Are you kidding? You really think a stock valve spring with over 100k miles has the same tension and resilience as a new spring? It's called wore out.....think about it. A wore out valve spring will 'bottom out' or not return to its original position more easily than a new stocker...Some never come back to the OEM free length ever so it's shorter than stock. Same idea as wore out coil springs that cause a car to sag and bottom out easily.
And I never state my opinions as fact...I just provide data as to what I feel would be a good choice. But, in the end it all comes down to the user. They don't have to listen to me...but there are others that believe the same as I do. Why push the edge when you can be safe?
No one here is a complete guru as you put it. But, I feel i'm rather knowledgable and have plenty of creditials and experience to back it up. What exactly in your book defines a guru? And why the need to come into a 'helpful' post with data and numbers just to bash on me? Do I know you? Or better yet, do you know me? Doubt it.
Back on topic.....
Wiz
Old 10-25-2007   #18
Re: Which cams?
Wiz
Wow, you need to learn what coil bind is. I agree that the springs will be weaker over time, but that doesn't have a thing to do with coil bind. Coil bind comes from the coil being too big and the cam having too much lift, causing the coil to bind. This obviously can't happen unless you think the spring grows over time.
Maybe it is just the way you word your post, but to say Webcams are good and Crowers should stick to NA cams because they can't make power on a turbo car is wrong. Several of us are making good power on Crowers.
Old 10-25-2007   #19
Re: Which cams?
FPs are Comp Cams actually.
http://store.forcedperformance.net/m...100_FPCam1.pdf
Old 10-25-2007   #20
Re: Which cams?
Stay off my cams!
