Old 12-03-2007   #41
Re: whats up
Welcome to Mitsu Style. With your setup I would install a FMIC and ARP head studs then port the turbo or try a LIPP cast o2 housing that we sell to fix the boost creep. Then turn it up to 20-21psi and it should make good power, then if thats not enough buy DSM link and try E-85 to max out the 16g.
Old 12-03-2007   #42
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: wats up
Do you have 680cc or you want to go to 680cc
If you have them you are set
You just joined and already there are plans from on how to modify your car!
ya i have the 680cc all that is done to my car is what i have done to it!! and i was told by LSE that if i turn the boost up that it would creep higher...
Old 12-03-2007   #43
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
that all sounds good but i ran into the issue with the tranny and now im stuck driving it in the winter and being at 10 psi in the winter should be fine im thinking.. but that also gives a chance to save up and do it all in the spring.. LOTS OF PLANS FOR THE SPRING!!!!
Old 12-03-2007   #44
Re: wats up
That is not correct. Boost creep comes from the wastegate not flowing enough, that has nothing to do with what the boost is set at. A boost spike will raise with the boost setting normally.
Old 12-03-2007   #45
Re: whats up
+1 (again woot JET), you should be able to turn your boost up to, say 16psi, and then it will rise up to 19psi by redline from the boost creep. You should then also be able to set your boost at 19psi, and it will not rise much if any by redline. If this is not the case, something else might be amiss...weird MBC or something?
I love the LIPP housing that LSE sells, it is awesome and I highly recommend it. On the same note, might be $$ more well spent on porting and DSMLink, so you can run E85 next summer
Old 12-03-2007   #46
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
so what your saying is if i port and do a dsm link it would stop my boost creep also??? or do i have to go with the LIPP in order so stop the creep??
Old 12-03-2007   #47
Re: whats up
Just porting would cure the creep, or you can port the turbo and put the LIPP on to stop it. Link won't do anything for creep, he was talking about running E85.
Old 12-03-2007   #48
Re: whats up
Ya like JET said, porting will help creep, and skipping the LIPP housing could earn you more money to be spent on DSMLink. With that being said, the LIPP housing is AWESOME, and not a waste of money in either way. I used it for about a year on my 2G, and I loved it. Just options options options for ya.
Old 12-03-2007   #49
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
well i appreciate the input on everything that you and jet have been saying there is just so many things that i wanna do to it.... i want to be running about 18 to 19 so if i just turn it up to 18 or 19 it shouldnt creep beyond 19 like you said....
i really want dsm link.. i already have a laptop that i just got like a week ago and i really want 272 cams!! i just cant make up my mind on what im REALLY gonna do next??? if what you say about the 16g being good for some power then i might stick with it for now but i really want to hit 300awhp by next summer
Old 12-03-2007   #50
Re: whats up
SAFC should be fine for a 16g. I would do cams next.
Old 12-03-2007   #51
blageo23
AWD4G64
blageo23's Avatar
Re: whats up
The only problem with running E85 is that there is no gas station around us that sells it. The closest one is on lexington and 35E or on 96 in whitebear. I wanted to go to E85 but noone sells it. Do you know if the gas station at the end of ware rd sells it?
Old 12-03-2007   #52
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
no they dont im really not sure about who sells it around us. you obviously know more about who sells it around here.
Old 12-03-2007   #53
blageo23
AWD4G64
blageo23's Avatar
Re: whats up
Cuz I want to run it REALLY bad. They need to sell it somewhere around here damnit!!!!
Old 12-03-2007   #54
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
ya but i have an idleing prob and i would like for my car to get a better tune on it...
i went to the dealership and they put a new IAC motor in my car and they set it at 750rpm's and i really dont like its too low so i try to turn it up but even if i do a little at a time the computer resets it back to 750 and i wanna run about 850 or 900 at idle....
Old 12-03-2007   #55
Re: whats up
You need to fix the problems then, don't just throw parts at it. You car should always be running good before you upgrade parts, right Swifty??
Old 12-03-2007   #56
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
so whats so special about E85 if i dont sound stupid asking
Old 12-03-2007   #57
blageo23
AWD4G64
blageo23's Avatar
Re: whats up
Higher octane. You can run higher boost, only bad part is you use alot more fuel.
Old 12-04-2007   #58
Re: whats up
Yep, cheap and you can run almost 30 psi on it.
Old 12-04-2007   #59
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
wow ok well thats something new that i learned today.. thanks for that input
Old 12-04-2007   #60
GsXtUrBo98
GsXtUrBo98's Avatar
Re: whats up
dont get me wrong, it runs good i just would like for it to idle at a higher rpm and it just wont do it for me plus i need to fix the lifters on the cyl. head anyways so while im getting that done i might as well just put cams in there ya know what i mean...
its not like its something i need just what i want!! ha ha
