Old 12-05-2007   #41
Re: Harmonic Tensioner Pulley BROKE OFF!
I guess I didn't think of this before, but it was probably taken off sometime and the bolts were over tightened. was it you that bought this from some kid/guy in iowa?
Scheides' car was a virgin when he bought it. You're thinking of Matt's car.
Old 12-05-2007   #42
E-brake drifts will make those lights come on every time.
Old 12-05-2007   #43
Yup, as far as I know those bolts were never touched.....it is due for a timing belt job in another 14k miles or so, but other than that my car was 100% unmodded when I bought it. Then I corrupted it
Old 12-08-2007   #44
Damn it, the bolts are seized in there....off comings the timing cover and belt....and another few days for another part
Old 12-08-2007   #45
shitty
Old 12-08-2007   #46
Chris, my cousin works at that Sinclair, I saw your car sleeping there last night.
Old 12-08-2007   #47
That sucks man! You might as well pull the engine and toss in a freshly built 2.3l!
Old 12-08-2007   #48
Any thoughts on his mechanical abilities?
Old 12-08-2007   #49
They have a L1 ase cert mechanic there that should beable to do a timing belt correctly.
My cousin is just the gas station attendant/pump bitch. Fills air, fills oil, stuff like that (he is 18).
Old 12-12-2007   #50
Got the car back last night. Dave at Golden Valley Sinclair worked on my car, I talked to him for quite a bit through the week and for about an hour last night when I picked up the car. I feel very confident in his abilities as a mechanic--it's not a Ferrari or anything (though it may be as fast as one?)! He pulled off the timing cover, pushed in the tensioner with the proper tool, and then yanked the pulley off and replaced it with a brand new one. Reset the timing and the reassembled. Not a full timing belt job but half way there at least. In the end I probably could have done it myself, but if anyone knows what happened at work the day before this happened, you would not want to deal with it either!
Here's some pics of the pulley, if you look closely you will see how the sheared off bolts got tweaked and goobered up the outside edge of a lot of the holes. The guide pin is gone as well, obviously left violently.
more pics here: http://www.scheides.com/gallery/evotimingpulley
I'll be doing a compression check and tossing it on the dyno here soon, I'm sure everything is dandy, the car runs like a top!
Old 12-12-2007   #51
Now i too have Janine's phone number! BWAHAHAHHAHHAHHAA
Old 12-12-2007   #52
Wow, that pulley hung on for quite a while after the balancer bailed. That is quite a bit of damage to the bolt holes. Hopefully the main bearings are ok with all that imbalance that was going on. If not, stroker time!
Old 12-12-2007   #53
Yup, I think everything is fine. I'll do an oil change and compression test for grins, but the car runs awesome. And JET yes you are right!
Old 12-12-2007   #54
X Factor
The Newbie
Glad everything is back in order!
2006 Mitsubishi Eclipse GT
X Factor is offline   Reply With Quote
Old 12-28-2007   #55
Changed the oil the other night and my oil filter has a few good dings in it:
I sent some oil off to blackstone just to see what they say about it, but I am sort of considering myself lucky for now, the car drives just dandy....put about 800 miles on it since getting it back together and no problems yet.
Old 12-28-2007   #56
polishmafia
Smells like cat poop
polishmafia's Avatar
damn! you need to stop snow drifting
those are some pretty severe hits it took. good thing it didnt split open.
Old 12-28-2007   #57
And I'm the pussy who wants to put another undertray on.
Old 12-28-2007   #58
tim
tim's Avatar
Dont these come from the factory with an undertray? I would think even a shitty plastic one would deflect some of this stuff.
Old 12-28-2007   #59
They do, but a lot of people remove them since they are a real PITA.
Old 12-28-2007   #60
I WANT an undertray, the stock one would not have blocked this. It does not reach back past the front of the block; the oil filter is completely exposed. I'm looking at this undertray that buschur is selling now, it goes back past the block and all the way to the wheel wells.
