Old 01-03-2008   #1
gstjoker
gstjoker's Avatar
Arrow FLYWHEEL: ACT or Fidanza?
I've researched all around for this already but I just wanted to know from this forum to see what you guru's in here would rather choose. My car's a 96 gst pushing 267whp at the LSE dyno awhile back. I'm going to be throwing in a Southbend DXD clutch in there and still debating about keeping the stock flywheel but I'm leaning more towards a new flywheel. And now it's the ACT flywheel or the Fidanza. Which one would you recommend or choose and why. Good or bad experiences?
Old 01-03-2008   #2
Re: FLYWHEEL: ACT or Fidanza?
I have a act in my talon fwd and one in my awd spyder they work great I have not ever had a problem with them at all. fidanza use to have problems with the rivits braking off on the mitsu's. I just like the 1 piece flywheels better
Old 01-03-2008   #3
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
I had a Fidanza for about a thousand miles and it was pretty nice. Never had an ACT though. Had the CFDF/Fidanza setup, I liked it. Swapped engines so the 7bolt flywheel is now a paperweight
I'm still trying to figure out if I'm going to get a 6 bolt Fidanza and use my CFDF with that again or go ACT 2600/ACT FW. Or Competition Clutch and maybe a Fidanza?
This topics been brought up all over teh intronetz but it's always fun to hear new opinions.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 01-03-2008   #4
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
I had the 8lbs Fidanza on my DXD SS FE for about 4000 miles. When I took it off to part it there was alot of heat soaking and wear. It appeared that it was in need of a replacement disk already. I'm not sure about fidanza because of that. And yes it was broke in properly.. Although even with it like that I never had a problem with performance. If I ever bought another it would be ACT never hear anything negitive on them.
Old 01-03-2008   #5
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
No problens with my ACT flywheel. 400+ HP daily FWD. I would recomend it to anyone looking to upgrade flywheels. If you go with an aluminum flywheel of any kind I'd recomend and auto spacer plate and longer bolts.
11.35 @ 120mph
Old 01-03-2008   #6
I have had a 9 pound fidanza flywheel on my car now for the last 10,000 miles, no problems, stock-like driveability, very nice unit.
Old 01-03-2008   #7
I have had both and I like the Fidanza more. The chrome moly in the ACT is more slippery than the surface on the Fidanza, so it will not hold as much power.
Mark - what rivets are on a Fidanza? I don't have any on mine, the friction surface is held on by screws.
The surface of my Fidanza didn't look too good when I took it off either, but it was working great. It has since went in another car and is working just fine.
Old 01-23-2008   #8
bouncer07
I like my Fidanza. The ACT causes problems.
bouncer07 is offline   Reply With Quote
Old 01-23-2008   #9
v8klla
v8klla's Avatar
I am a big fan of the Fidanza for performance applications simply because you can replace the friction surface rather than the whole flywheel the next time you replace your clutch.
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 01-23-2008   #10
Joe's Fidanza worked great!
Old 01-23-2008   #11
Agreed, I've had better luck with ACT's.
Old 01-23-2008   #12
ARHGHGHGHGHGHGHHHGhghgkshg;lksahgkjak!!!!!!!!!!!!! !!!!!1111111
Old 01-24-2008   #13
driftn1g
go fidanza
