Old 02-06-2008   #1
GnArKiLl
GnArKiLl's Avatar
mbc wont work
ok well my car will not hold constant boost i have tryed 2 mbc's and both have done the same thing..
i have my mbc set at 0 psi turned all the way down and it still goes past 20psi on my gauge. i have it tapped into the bov like its spose to be. i have tryed changing the wg actuator but still doesnt work.
what else could i try
Old 02-06-2008   #2
Re: mbc wont work
Do you have a pressure source on the turbo?
Just run a vacuum line from the pressure source like the intake mani or turbo and run it straight into the wastegate actuator. That should run the same boost pressure as the wastegate spring, 10 lbs or whatever.
If that doesn't hold boost down then it's the actuator or flapper not opening when it should.
Old 02-06-2008   #3
Re: mbc wont work
Does it go to 20psi right away or does it slowly go up there as the RPM increases?
Old 02-06-2008   #4
Re: mbc wont work
Tell us more about your setup. What kind of MBC? Are you sure you are adjusting it the correct way?
Old 02-06-2008   #5
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
jet- it will hit 20+psi almost right way less than 50% throttle
kracka- its a turbo xs mbc and yes i am adjusting it the right way.. the car is on a 14b stock side mount 3" exhaust all free mods done thats about it
Old 02-06-2008   #6
Re: mbc wont work
What doe sit do with no boost controller? Just a vaccum line from the wastegate to a boost source?
Are you sure the lines to the MBC aren't backwards? Turbo XS boost controllers often work the opposite way off most boost controllers. Make sure there aren't any holes/cuts in your vacuum lines too.
Old 02-06-2008   #7
Re: mbc wont work
I bet you're getting insane boost creep, my 1G did this too when I installed a turboback exhaust on a stock turbo/o2 housing (back in 2001). Check what Shane suggested first and if thats not it I bet its creep.
Old 02-06-2008   #8
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
i know it is hooked up right thats for sure...
im gonna try and run a line from the jpipe to a wg and see what happens
Old 02-06-2008   #9
Re: mbc wont work
Your wastegate flapper may be stuck also. Try moving the linkage with a pliers.
Old 02-06-2008   #10
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
ok well i tryed running wg boost and that did not work, it spooled alittle slower but still 20+psi..
Old 02-06-2008   #11
Re: mbc wont work
Boost creep, stuck flapper, or bad wastegate actuator.
Old 02-06-2008   #12
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
ok im gonna go check some things ill let you guys know
Old 02-07-2008   #13
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
well the flapper is not stuck and the actuator seems to be working its not getting stuck or anything.. iv already tryed 2 actuator's but ill try one more.. what would give me such bad boost creep?
Old 02-07-2008   #14
Re: mbc wont work
The restrictive stock turbine housing and stock o2 housing with a free-flowing turboback exhaust. Time to do some porting (or upgrade stuff)!
Old 02-07-2008   #15
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
my hot side is ported
Old 02-07-2008   #16
Re: mbc wont work
Is your O2 housing ported for better boost control? What turbo is it? Does it have a stock size flapper on it still?
Old 02-07-2008   #17
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
in running the 14b... i have the manifold and housing ported but not the o2 housing. still stock flaper
Old 02-07-2008   #18
Re: mbc wont work
You could also disconnect the flapper arm from the actuator, that would force the flapper open 100% of the time. I accidentally did this once and I could only get 8 or 9 lbs of boost by redline on my internally gated 20g.
Someone correct me if I'm wrong, but if it still goes over 20lbs then it's insane boost creep, right? And if boost stays low then the actuator isn't opening the flapper properly?
Old 02-07-2008   #19
Re: mbc wont work
Did this start when you put the new exhaust on? If so, it is just boost creep.
Old 02-07-2008   #20
GnArKiLl
GnArKiLl's Avatar
Re: mbc wont work
no it was doing it befor the new exhaust.. befor i had to set the boost controler at almost 0 and it would go to 15-16 psi.....
