Old 02-19-2008   #41
Re: 4B11T engine pics - the guts!
Faster bearing speeds, which would create more heat, and more likely to spin if you rev it high, but I do not know how big is to big.
Old 02-19-2008   #42
Yes the bearing speeds will be higher BUT there is also a greater surface area to take the force. The oiling properties have MUCH more to do with durability at higher speeds than just bearing diameter. You can't tell from those pics, but the X rod may be wider too, which would create even more surface area.
Old 02-19-2008   #43
Dizmm
Dizmm's Avatar
Drives: on ICE
hard to tell from just a picture, maybe they are a bit wider which will put less load on the bearing as a whole. Time will tell i guess. There are pro's and cons to the new 4b11 just like any other engine.
Andy Smedegard
Dizmm is offline   Reply With Quote
Old 02-19-2008   #44
OH NOES THEY BROUGHT THE 7BOLT BACK!!!
Old 02-19-2008   #45
Evo 8/9 is 7-bolt.
Old 02-19-2008   #46
Dizmm
Dizmm's Avatar
Drives: on ICE
can someone explain what the gear is on the evo X crank? is that for the oil pump?
Andy Smedegard
Old 02-19-2008   #47
Crank sensor.
Old 02-19-2008   #48
Evo 8/9 is 7-bolt.
All evos have been 7-bolts yo!
Old 02-19-2008   #49
Dizmm
Dizmm's Avatar
Drives: on ICE
Crank sensor.
interesting.
Andy Smedegard
