Old 02-23-2004   #21
Originally posted by TalonTSiDude@Feb 23 2004, 10:54 AM
Everybody should buy fishtank bleeder-valves and use them as boost controllers...since they get the job done, they must be good!
Naw, too expensive. Just poke random holes in the vacuum line going to the wastegate until it makes the boost you want.
Old 02-23-2004   #22
Wow! I never thought of that.
Old 02-23-2004   #23
JiN
JiN's Avatar
I have a friend who made his own too. And it worked fine. But I for one wouldnt trust or put that shit on my car. I've had too many big problems that were caused over stupid shit. Just be safe about it. Sure you may save some money by going cheap...but when shit goes wrong, you'll be really sorry and you'll be kickin yourself in the ass for not doing shit the way it should've been done.
Evil=Anything that can bleed for seven days and not die. Description: Women.
JiN is offline   Reply With Quote
Old 02-23-2004   #24
Originally posted by TalonTSiDude+Feb 23 2004, 11:25 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TalonTSiDude @ Feb 23 2004, 11:25 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-ecoli@Feb 23 2004, 12:12 PM
Naw, too expensive.&nbsp; Just poke random holes in the vacuum line going to the wastegate until it makes the boost you want.
Wow! I never thought of that. [/b][/quote]
Thats how you get around class rules that don't allow boost controllers.
Old 02-23-2004   #25
1Fst14B
Send a message via AIM to 1Fst14B
wow.
thanks for showing me that you dont know shit.
fishtank bleeders...puhlezzze, that was like 5 years ago...
Adam
1Fst14B is offline   Reply With Quote
Old 03-06-2004   #26
JoeGengsta
Send a message via AIM to JoeGengsta
My Joe G boost controller is better, ask Dane, Colin, Chris. etc... and no, i said Joe G, not Joe P. i make it.
Subaru Impreza STi
JoeGengsta is offline   Reply With Quote
Old 03-06-2004   #27
BTW are you actually reading boost now? LOL
I found a noticable increase in performance by getting an Elite MBC (Great MBC, thanks guys) and a aftermarket Turkey call (BOV). I have the K&N filter but the intake pipe is stock and the exhaust and UICP is stock also. Its just a matter of wether you want huge performance or just something to give ya a little more balls. either way if you havent gotten this from the thread already dont make your own unless you know what your doing. $30 at elite is about the best price your gonna find, and they are very nice and accurate. either that or get a Apexi AFC then you have a nice little blue display. LOL
Old 03-06-2004   #28
Originally posted by tpunx99GSX@Mar 6 2004, 04:00 PM
..... or get a Apexi AFC then you have a nice little blue display. LOL
Don't you mean AVC-R? :stick: :bounce:
Old 03-07-2004   #29
yeah, shouldnt you be on ebay. :bj: :stick:
Old 03-08-2004   #30
john
Business as usual
john's Avatar
An AVC-R is not much more than a blue screen. I could not get the damn thing set on my car. My hallman was very reliable.
97 Viper GTS
Old 03-08-2004   #31
Originally posted by 1Fst14B+Feb 23 2004, 07:53 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (1Fst14B @ Feb 23 2004, 07:53 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TalonTSiDude@Feb 23 2004, 10:54 AM
wow.
Adam [/b][/quote]
Oh for Christ's sake does nobody understand sarcasm anymore? :fworld:
Old 03-08-2004   #32
booooozt
Old 03-08-2004   #33
Originally posted by ecoli@Mar 8 2004, 01:53 AM
booooozt
Exactly!
Old 03-08-2004   #34
JiN
JiN's Avatar
[/quote]
Well if it is acurate, then my damn MBC wont tune my boost. I'll run 13/15 all day. No matter if that thing is all the way in or out. Does anyone know, on a 2g, if the line you tap for a boost gauge has blue lines on it or not?
Old 03-08-2004   #35
npaulseth
Any of the vaccum lines coming off of the intake manifold will work best.
Old 03-08-2004   #36
john
Business as usual
john's Avatar
Tap the bov line (obviously not the recirculation tube though).
97 Viper GTS
Old 03-08-2004   #37
For 1G's, I prefer to use the turbo-outlet elbow (when still using a TDO5H turbo).
Old 03-08-2004   #38
john
Business as usual
john's Avatar
I did it there but I was told it makes the turbo seem more laggy. I had no problems though.
97 Viper GTS
Old 03-08-2004   #39
Back when I had my MBC tapped into that outlet-elbow I got zero boost-spike, when moved to the BOV line during the FMIC install I started getting about 2 psi spike. I have also switched a lot of people's cars over from the BOV line to the elbow and never got a complain about it making the turbo more laggy, but everyone did say it eliminated the spike (or at least seriously reduced it).
Old 03-08-2004   #40
Boost leak? Or just the weak T25. Does it at least spike past 15 to start? The T25 will only hold like 13-15psi in the high RPMs.
If your gauge reads vacuum on intial startup then your probably on the right line. Even if your on the wrong line, if your getting a boost reading then it should be accurate if there is no leaks.
Tapping of the BOV or comp housing or comp elbow should have no effect on spoolup time. Think about how it works...
Tapping of the BOV line should give somewhat more consistant boost levels from one day to the next because it takes into effect how well or not so good the intercooler is doing it's job. Getting it pre-intercooler pretty much makes the turbo always run the same boost, but you could end up with varying boost levels at the intake manifold/motor depending on how heatsoaked the intercooler is because the better an intercooler is doing at it's job of cooling the more pressure drop you will get post-intercooler.
If you are trying to run as little boost as possible, then tap it pre-intercooler. Then the wastegate will get to see the most amount of boost pressure the quickest and be able to open sooner.
