Old 03-10-2004   #21
remy
Guest
Tournaments Won: 6
Posts: n/a
oh you wait and see what will be rolling around hapkins this year. Are you scared? :3gears: Good you shouldn't be.
Old 03-10-2004   #22
Iceman
That HORT shit is gay. I'm thinking HWY like Hopkins whinning youth or Hopkins Wary Youth LOL.
Old 03-11-2004   #23
a-lo
Guest
Tournaments Won: 6
Posts: n/a
back to the subject of the way my evolution is acting and the fact that i am 50% turbo illiterate. what would be the correct way to tune it and what are the pro's and cons of "softer or harder" adjustment. that valve should not vent at idle but how much tighter should it be???
Old 03-11-2004   #24
the 'softness/hardness' is how much boost the valve actually opens before it opens/how it actually opens. A setting to hard or too soft can actually create a book leak/flutter/low boost holding capibilities. I'd recommend starting soft and working you way harder. You'll know when its right.
Old 03-11-2004   #25
a-lo
Guest
Tournaments Won: 6
Posts: n/a
whats going to be my tell tail sign that its right, i'm not sure what i'm looking for. do you or anyone have any recomendations on a good place or book it read up on some turbo tech.?
Old 03-11-2004   #26
Here is a decent source if you can weed between the bs and the straight and arrow. Books, go do an amazon search.
Not sure on many evo related sites, but the big dsm sites offer some good tech info (again see disclaimer above).
You'll know when its right when the 'flutter' is gone, the boost doesn't leak at idle, and the car is strong and holds the amount you want to run.
Old 03-11-2004   #27
DSM-Talk
DSM-Tuners
Both great places to start. There should be more than enough info on both of those boards about your BOV.
Old 03-11-2004   #28
a-lo
Guest
Tournaments Won: 6
Posts: n/a
thanks
Old 03-11-2004   #29
a-lo
Guest
Tournaments Won: 6
Posts: n/a
i found a bomb ass site with the info i needed on my problem. it seems like a cool site anyone with an evo should check it out if they haven't already.
http://www.evomoto.com/tech_info.php?techID=23
Old 03-11-2004   #30
john
Business as usual
john's Avatar
Originally posted by TalonTSiDude@Mar 9 2004, 02:35 PM
There are so many reasons why that is a bad idea...more unmetered air to screw up how the car runs, unfiltered air, totally ghetto, and the list goes on.
You are worried about a little air when you are cutting a MAS in half and soldering some resisters in? I can tell you now that your MAS is worse than a breather filter sucking in a little air on the recirc tube.
97 Viper GTS
Old 03-11-2004   #31
Mr. Ghetto said nothing about putting a small filter on...he said to cut the recirculation tube.
Old 03-11-2004   #32
This is great!! :woowoo:
So what was this thread about? :bounce:
Old 03-11-2004   #33
1) getting an EVO to run properly
2) :bounce:
Old 03-11-2004   #34
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
The way that Korey did it was he got a tee fitting and put a kitchen faucet strainer on the open part of it. I did this as well a while back and had absolutely no problems with it. Never ran lean, never detonated, never knocked. I am not promoting it but you can do it without any problems. It will give you a little louder blow off.
I don't have it in mine anymore. Mine is plenty loud with the open airbox. Mine is vented back the way it was from the factory. I did have fun scaring the hell out of people waling down the streets. Especially watching their dogs jump when the blow off valve hit really hard.
