Old 07-22-2008   #1
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Turbo manifold Bolt broken!
I havent driven the GVR4 for about 2 weeks ( ) and i checked out my engine just because i missed it so much. I was just looking around and saw that ONE bolt holding the turbo to the exhaust manifold broke! i havent been driving it because of a ripped brake line. ugh...i miss driving it. Well, anyways, where do you guys recommend buying 1 turbo manifold bolt? i will have pics of it tommorow. thanks!
ლ(ಠ益ಠლ)
Old 07-22-2008   #2
Re: Turbo manifold Bolt broken!
Getting the bolt is easy, go to Mitsu. Getting the old bolt out might be the fun part! Those things are damn hard. Hopefully some of it is sticking out and you can get a good vice grip on it to remove it.
Old 07-23-2008   #3
JET, you saved me with a few cases like this in years past! Hopefully it comes out easy man, otherwise just drive it on 3 and hope it doesn't leak :P
-scheides
Old 07-23-2008   #4
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
I know STM sells studs individually. http://www.streettunedmotorsports.com/dsm/dsm_oem.htm
But, HANDLING fees bite.
Try something local like a dealer, or buy a bunch of parts.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 07-23-2008   #5
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
-scheides
Well it depends on how long the car is going to be down. If more than a couple days then drill the old one out and chase the threads. I had to do this once, it was a pain in the you know what, but it worked.
Mwolf83 is offline   Reply With Quote
Old 07-23-2008   #6
awd-drifter
'2of9'
yeah...luckily it seemed like it unscrewed itself from the manifold so it isnt stuck down there. well...another question, should i use something so the new screw does not seize when i replace it?
ლ(ಠ益ಠლ)
Old 07-23-2008   #7
anti-seize on them. If you need a bolt I have a ton on them
Old 07-23-2008   #8
93gtpeater
Drives: cbr 1000rr repsol
i used helio coils on my buddys car and arp studs and never striped or snap. make sure you tightin them down to torque spec.
