Old 08-01-2008   #1
Blown Head Gasket?
- white smoke (especially at idle)
- 90s across the board for compression.
- Hard to get started, Sounds like a subie when it finally starts.
- Runs like ass.
- Coolent is running a little hot.
- Evo 3 Metal Head Gasket that has been on a couple of my engines, and head changes, Applied Copper Spray this last time i put the 1g head on. The normal sealant was looking a little tired.
- Torqued and retorqued to 76 ft/lbs.
Sound like a head gasket to you guys?
Old 08-01-2008   #2
twack
It was a auto get over it
twack's Avatar
Re: Blown Head Gasket?
I would say so, i would get away from the metal head gaskets in my opinion
Old 08-01-2008   #3
311evo
311evo's Avatar
agreed, also maybe every once in a while when your changing your head/engine you could pick up a new gasket.
Old 08-01-2008   #4
Reused head gasket?
Old 08-01-2008   #5
lol! Reusing a headgasket? You have got to be kidding me.
Old 08-01-2008   #6
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
This guy never catches a break.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 08-01-2008   #7
You can reuse metal headgaskets, I've done it several times with no problems. However going with 76 lb/ft is a little weak in my book. I torque my ARP's(used several times as well) to 95 lb/ft with oil.
I did have mine go early this year with no real explanation, I wasn't on it at all. The only real thing I can think of was I had my timing set up wrong in link. The symptoms were exactly as you're describing.
Old 08-01-2008   #8
Naw, it's fine. Keep running it until it's down to running on 2 cylinders instead of just 3 and it gets enough coolant in the cylinders to bend a rod or two.
Old 08-01-2008   #9
Thanks, Yeah i have never had issues with compression until this last time. Ive always made sure to put a nice coat of Copper Spray on the Head Gasket and never had any issues. Looks like im going to have to take the head off AGAIN!
Old 08-01-2008   #10
And while your at it, make sure those headstuds are a bit more than finger (76lb) tight .
Old 08-01-2008   #11
I have reused them before. the one on the talon has been off 4 time still same multi layer and seals fine still with copper spray and arps down to 95
Old 08-01-2008   #12
Stock headstuds. And i really dont want to snap them.
Old 08-01-2008   #13
Reused head gasket?
Reusing metal headgaskets is nothing new.
Old 08-01-2008   #14
You're using stock headbolts? I thought you were running in the 20s for boost, maybe they stretched. With all this money/time you put into it, should splurge for ARPs.
Old 08-01-2008   #15
Yeah i run 25-27 daily.
I may pick some up, otherwise i think i have a set of 6bolt ARPs to go with my 1g head. I would have to tap the block though.
Old 08-01-2008   #16
You can't reuse stock head studs! Spend the $80 for ARP's and save yourself all this hassle.
Old 08-01-2008   #17
Cant = Shouldn't. I know you shouldnt but these have worked fine for the time they have been on the car. Yes im planning on getting some ARPs now and a new metal head gasket. Anyone know the mitsu part number for the evo 3 head gasket?
Old 08-01-2008   #18
nm found it Part no: MD349347
Old 08-01-2008   #19
You can reuse the mitsu metal mutli layer HG? That would be news to me.. I dont think id ever reuse something that critical.
Tom, I thought you were getting out of dsms. :P
Old 08-01-2008   #20
Metal head gaskets dont blow like oem ones, so usually you can copper spray them and it will still seal just fine. But the raised sealing material has wiped off after using it multiple times.
I have tried many times to get out of dsms, but i just cant give up on a car that is:
a) Completly paid off
b) i have spent so much time and effort on. (and money)
c) usually works.
d) has everything i have wanted in a car.
