Old 08-19-2008   #1
INTRIGUED
insert witty title here
INTRIGUED's Avatar
Drives: VW Gti
Receivers for surround sound
Well today I bit the bullet and finally went and got a new receiver
http://www.sonystyle.com/webapp/wcs/...4791&langId=-1
Got a pretty good deal on it I think, Just curious what you all have. One thing I didn't like is this doesn't have a plug in for a non powered sub. Only has the component style plug, So I just tapped into one of the front speaker ports.
Old 08-20-2008   #2
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Receivers for surround sound
Sony receivers are wonderful. I've got an STR-K700 myself.
And yeah, powered subs suck.
Originally Posted by Trogdor
Old 08-20-2008   #3
runninW.O.T.
Where is my custom title?
Herculympics Champion! Conquer Antartica Champion! Hybrid Fighter Champion!
Spend the cash for a powered sub. My cuz bought a sweet 1000 rms one You can hear it bump from 4 or 5 blocks away!!!
That's a bold strategy Cotton ... Let's see if it pays off for 'em!
runninW.O.T. is offline   Reply With Quote
Old 08-20-2008   #4
mdost03
Sonic Champion!
Drives: VA STI
STR-DG810 here myself.
I like Sony Receivers.
Old 08-20-2008   #5
INTRIGUED
INTRIGUED's Avatar
Drives: VW Gti
I'm pretty happy with it so far, Just ended up doing the 7.1. I only have a 5.1 set up right now but its pretty easy to just pick up two extra speakers. Had to order up another HDMI cable though, Kinda nice this thing has 4 in and only 1 out though. Not sure what I'd even use the other ports for, PS3 has one and thats pretty much all I have right now. One nice thing about this model it just doesn't pass through the HDMI signal, It does both video and audio in just the HDMI cable. Apparently I would have to have a optical to do the audio with the model below this one.
Old 08-20-2008   #6
My 5.1 home theater....
Onkyo TX-SR504 receiver
PSB Alpha T towers
PSB Image C40 center channel
PSB Alpha LR1 surrounds
PSB Subsonic 5i subwoofer
Old 08-20-2008   #7
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Denon AVR-5805... yeah right, I wish!
Avatar = Small Turbo:confused:
mukapahnpy is offline   Reply With Quote
Old 08-22-2008   #8
INTRIGUED
INTRIGUED's Avatar
Drives: VW Gti
http://www.audioreview.com/cat/speak...6_2741crx.aspx
Another new item today, I'm on a electronics kick I think..
Old 08-22-2008   #9
95tsi
95tsi's Avatar
Drives: a pos
I dunno about that. I kinda like them and every decent hometheater system or speaker system seems to have them.... I have 2 going in my room;a 250w KRK 10" hitting at about 36hz and a 500w Infinity 12" hitting down to around 20hz, and thinking about building up another. Reciever is a Yamaha HTR-5490 then its Definitve Technology for the front and rear towers and center.
Old 08-22-2008   #10
cmspaz
Walls need hugs too
cmspaz's Avatar
Yeah, but half the time, I'm not listening to music at a high enough volume to trigger a powered sub, even with the sensitivity all the way up. A non-powered sub doesn't have that problem.
Old 08-22-2008   #11
95tsi
95tsi's Avatar
Drives: a pos
You shouldnt need to listen at crazy high levels to 'trigger' the sub. The sub gets the same sound signal just is non-powered. So, you should be able to adjust the volume on the sub to make the proper sound for the frequency and the volume. The problem with a non powered sub, in my opinion, is the reciever generally dosnt have enough power going to it to really make it effective at certain frequencies.
Old 08-26-2008   #12
INTRIGUED
INTRIGUED's Avatar
Drives: VW Gti
You guys have any preference with banana plugs? Not a fan how the speaker wire connects to the back of this thing and from what it sounds like these plugs work well and just plug right in the back and do the trick. Any direction you want to aim me at?
Old 08-27-2008   #13
95tsi
95tsi's Avatar
Drives: a pos
I'm using both the banana plugs and just straight wire on mine. The plugs are much easier and might make a better connection, but who knows... certainly are easier though!!!!
