Old 09-12-2008   #1
mdost03
Sonic Champion!
Drives: VA STI
Anyone with the HKS 272 cams? Have a question...
Alright, I currently have the new Tial Q BOV and have the 10 psi spring in it which is good for -16 to -19 vacuum. I am now going with the HKS 272 cams and was wondering if anyone knows what kind of vacuum they read so I know what spring to buy for the BOV. Here's the BOV spring rates:
-8 to -11 in/HG use 6 PSI Spring (Black)
-12 to -15 in/HG use 8 PSI Spring (White)
-16 to -19 in/HG use 10 PSI Spring (Silver)
-20 to -21 in/HG use 11 PSI Spring (Purple)
I am thinking I am going to have to go with the white spring, but wanted to make sure. So anyone with the HKS 272 cams, what kind of vacuum to you read? Thanks!
Old 09-12-2008   #2
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: Anyone with the HKS 272 cams? Have a question...
Usually around 12inhg lowest to 17ingh highest. I usually sit around 13-14 with mine.
-1990 Mitsubishi Cyborg 4WD-
Old 09-12-2008   #3
Prolly the white (8psi spring), just from what I've seen.
Old 09-12-2008   #4
When I start it cold, I see about 15, and at idle, I see about 11-12. However on decel, I see as much as 24.
Old 09-12-2008   #5
mdost03
Sonic Champion!
Drives: VA STI
Well I bought the silver spring today. I should be ok then with vac conditions now?
Kevin, you say you see -24 sometimes, should I have just left the spring alone or would you have recommended me change to the smaller spring?
Old 09-12-2008   #6
I thought it should always be around -24 on deceleration, no matter what the cams. On stock cams I saw a lot of vacuum at idle, and -24 on decel, now with bigger cams I see only -12 at idle and still -24 on decel.
Old 09-12-2008   #7
mdost03
Sonic Champion!
Drives: VA STI
So would putting the smaller spring on there hurt it at all if -24 is the norm? I thought you bought the springs based on what the idle vac was.
Old 09-12-2008   #8
I run a 11psi spring in mine craig used a 11psi spring with his 280's
Old 09-12-2008   #9
I have the 11 psi spring in my Tial, and I don't have any problems with it.
Old 09-13-2008   #10
mdost03
Sonic Champion!
Drives: VA STI
Hmm, wish I would have known this before ordering the $30 spring haha. Oh well, I'll try both ways and see if there is any difference.
