Old 10-31-2008   #1
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Best way to Bandaid a torn lower ball joint cover?
I need a temporary fix. It's not bad, maybe an 1/8th of an inch long but If it is driven this winter it will get worse eventually.
OmgAwd is offline   Reply With Quote
Old 10-31-2008   #2
Re: Best way to Bandaid a torn lower ball joint cover?
Wrap it with duct tape! Kind of hard to repair a rubber boot that is covered in grease and grime.
Old 10-31-2008   #3
SnoEclipse
Drives: 07 Eclipse GT
or go get a tire tube repair kit at the local bike store.
Clean the boot really well and get the patch put on. Make the patch as big as you can without interfering with the flex of the boot.
Let the patch cure for at least 24 hours. I know that instructions will probably say 15-60 minutes, but that's for a bike tire. Your ball joint boots will be taking a tad more flex than a bike tire so you want the cement to have a good chance at making a good bond.
Now go out and abuse your car and check the patch when you get home. If it held up, you'll probably be good to go for the whole winter. But keep an eye on the boot just the same to make sure it doesn't open up again and let the winter road chemicals get to the ball joint.
SnoEclipse is offline   Reply With Quote
Old 10-31-2008   #4
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Or just replace it....
Old 10-31-2008   #5
I vote replace it.
Old 10-31-2008   #6
OmgAwd
OmgAwd's Avatar
I said it was temporary guys. Of course i will replace it.
Old 10-31-2008   #7
OmgAwd
OmgAwd's Avatar
That sounds pretty good. I think I have a few laying around.
Old 10-31-2008   #8
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Silicone adhesive, pull it off, parts clean it, silicone adhesive, put it back on, and your good. Its what I did on mine. they are still holding
Old 10-31-2008   #9
OmgAwd
OmgAwd's Avatar
I heard about that but where can I find some?
