Old 01-13-2009   #21
mike55112
mike55112's Avatar
Drives: 04 evo
Re: My new setup for spring.
And then you launch on the street and blow up your drivetrain That's the only way I'll beat you!
I wont launch my car till I know I have the funds to send the tcase and trans in to shep. I will just wait and see how big my tax refund is
Old 01-14-2009   #22
Shane55113
Now 20% less Racist
Shane55113's Avatar
Sweet, i cant wait to go for a ride!
Old 01-14-2009   #23
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Originally Posted by mike55112 View Post
How can you be jealous, your car is gonna be hot. Let me know if you need any help, lizzy and rachel can sit and watch us work on your car or go find something to do.
Well an evo is still a must have in my book for someday but I am way too hooked on my car to start putting my money into another car right now....
As soon as I get the money wich should be anytime now I'm going to be putting that engine in and pulling the 7 bolt!! But when I do it Im going to do it right the first time and get the lower end built atleast. At the same time I'm planning on going to a bigger turbo then after that all I will have to worry about is the same as you "TRANNY, TRANSFERCASE"
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 01-14-2009   #24
mike55112
mike55112's Avatar
Drives: 04 evo
Ya I really hope I can at least make a couple passes at the track in the spring. I know this setup in the fall with ron driving ran a 11.4@124 with a 2.1 60 foot. That pass, the throwout bearing came apart. This was on pump gas too, I want to run my full blown dual pumper with e-85, but that still all depends on my driving and if my tranny and tcase can hold the power.
Old 01-14-2009   #25
That looks like a pretty badass setup! Who is gonna be tuning it for you?
Old 01-14-2009   #26
mike55112
mike55112's Avatar
Drives: 04 evo
Ron at RS is going to be tuning it. He already made 527 on this setup on pump at 28psi with the magnus cast intake manifold. Im gonna run the stock intake manifold for now. But in the spring im gonna be running e85 with the dual pumper. So I guess I will see what the stock ignition can do and then upgrade once thats maxed.
Old 01-14-2009   #27
That thing should move!
Ever think about getting your full blown setup anodized? I wouldn't be too worried but if you plan on running e85 for a while it'd be something to think about.
Old 01-14-2009   #28
brando
Drives: gutlass
shits gonna be sick cant wait to see some vid
Old 01-15-2009   #29
mike55112
mike55112's Avatar
Drives: 04 evo
I will try and get some video of the car on the dyno next week, as for now I have the car at home and I took a few pics of it today with a real camera. Here they are.
Old 01-15-2009   #30
Nice. And you know you can use the oil cooler, you just need to flush it out really well.
Old 01-15-2009   #31
I was curious as to why it couldn't be reused also...
Setup looks great though!@!!
Old 01-15-2009   #32
I also am inclined to believe that the oil cooler lines are fed after the filter, but I could definately be wrong on that. Can someone help out here?
Old 01-15-2009   #33
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Oil cooler is after the filter, but the filter has a bypass on it for when the oil is thick, like cold starts, or when the filter gets clogged.
I would not re-use the cooler. Have you ever cleaned an oil pan with bearing material in it? Even when you can touch it, it can be though to get everything out. If you think you going to get everything out by "flushing it out real good" dream on. Once 10 GPM of oil is pumping through that thing, any little spec you didn't get will work it's way out and into your motor.
Old 01-15-2009   #34
then I'd better clean my own cooler really really good.
Old 01-15-2009   #35
That thing looks pretty wicked!
Old 01-15-2009   #36
mike55112
mike55112's Avatar
Drives: 04 evo
I didnt reuse my cooler, I got a new one. My car is running off wastegate pressure and still rips pretty hard, I will be going back to rs when its not so cold out to get some numbers.
Old 01-16-2009   #37
brando
Drives: gutlass
sick man cant wait to see the numbers
Old 01-16-2009   #38
mike55112
mike55112's Avatar
Drives: 04 evo
I cant either, I got on it a little tonight and wow. for only 12psi it pulled hard. Cant wait to see how it pulls at 24psi
Old 01-16-2009   #39
brando
Drives: gutlass
yea. should be a sick ride
Old 01-16-2009   #40
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
man, i kinda want an evo again...ugh
'04 Honda Ricer: stock
