Old 01-15-2009   #41
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Re: This years taxes!
I used Turbo Tax last year for the first time. I found it very easy to use and quite helpful when filing my capital gains and options trades. I think the program was about ~$30 for the "Basic" version.
Old 01-15-2009   #42
I've been using TurboTax Online for something like 6 years. Very easy to use and far more convenient than going to a place like H&R Block, plus they keep all of your previous years' information so you don't have to look back at your old documents every year.
Old 01-15-2009   #43
I use TaxSlayer online, it's only $10 and super easy to use. Not sure about the more complicated stuff, I only use the basic deductions.
Old 01-15-2009   #44
hippiekiller
hippiekiller's Avatar
My girlfriend had been using tax slayer as well. Last year I made her do both, her return on Turbo Tax came out about $400 higher. All the same info as I watched her put it in. You don't have to pay for turbo tax if you don't file with them so I would suggest trying it once. Also, if you go the IRS' website there will be a link for turbo tax, if you click it your federal filing will be free.
hippiekiller is offline   Reply With Quote
Old 01-15-2009   #45
Good info, thanks! I used tax-slayer, but I am curious to see what both will say this year.
Old 01-15-2009   #46
hippiekiller
Yeah, if nothing else it can't hurt to check them both out and compare.
Old 01-15-2009   #47
TaxACT.com
I recommend everyone who uses TurboTax, to try TaxACT. I always use them, and for me their software is just as simple as TurboTax, but the cost of filing is cheaper.
I've used TaxACT the last 3 years, and every time I do it online, I also go and do them on TurboTax to compare the return, and they are always the same. Just TaxACT is half the cost of TurboTax to file so I file with TaxACT in the end. It's free to try it out up until the point when you press the FILE button, so it doesn't hurt to just give it a try.
Old 01-19-2009   #48
This is my first year with two jobs at the same time, I have heard it may "hurt" the return I would get. Anyone have any real knowledge about this?
Old 01-19-2009   #49
it hurt me every year i've done taxes, since I was 14. This is the first year I DON'T have more then one to file..
I never got why it hurt me though..I'm paying the gov. more money then I would be on 1 job.
-A. Swift
Old 01-19-2009   #50
Does your second job bump you up into another tax bracket? If both your employers are taking out money for taxes based on your anual wage being in tax bracket "x", but in actuallity since you have two jobs which means you're making enough that you are actually in tax bracket "y", then I can see it affecting you. Otherwise, I guess I don't see how it'd affect you.
Old 01-20-2009   #51
bill
I have my mom do my taxes every year because she works at a tax place. Nothing beats getting it filed for free. And I am getting back about 5500 this year. It is going to buy quite a few goodies. But I don't know how much I will actually use for the Talon.
The trouble with the world is that the stupid are
cocksure and the intelligent are full of doubt.
bill is offline   Reply With Quote
Old 01-20-2009   #52
That's a nice chunk of change!
Old 01-22-2009   #53
I just did my taxes online with TurboTax and TaxAct; both showed the same refund amount for me, but filing with TaxAct was $36 cheaper so I went that route. TurboTax is more user-friendly with less crap, ads, etc. on the site, but for a $36 savings I'll click "no thanks" a few times.
Old 01-22-2009   #54
Awesome, I'm not alone
Old 01-22-2009   #55
For sure, it was your recommendation that made me decide to look beyond TurboTax (which I've used the past few years).
Old 01-23-2009   #56
john
Business as usual
john's Avatar
Working more than one job will not directly hurt your return. Withholding choises are what matter.
Say one person works 2 jobs. Each employer will probably withhold a lower amount (say 15% tax bracket each job). Then, lets say by the end of the year, the individual's total income exceeds the 15% tax bracket and they are in the 25%. They owe 25% tax on certain wages which they only withheld 15% and a greater tax liability (or less of a refund) can happen.
If one is on salary for an income in the 25% tax bracket, they will typically withhold more money (to cover the $25% tax) and it will seem like a normal year.
Having two jobs isn't the problem though. This can be planned for and avoided with some tax planning.
97 Viper GTS
Old 01-23-2009   #57
john
Business as usual
john's Avatar
I am not sure what to expect. I worked all tax season, took all summer off, then worked again. I am not going to file for my partnership as I plan on being in a higher tax bracket next year and would rather have the expenses written against a higher rate. No late file penalty for LLCs under 10 members. Worse case they make me file and claim a larger refund. Have two houses with loans, one without any loan, and a bunch of property taxes paid. Should get back a nice refund aswell.
I will be using the software at work as I can e-file for free.
97 Viper GTS
Old 01-23-2009   #58
SLOW_V
^^I had never known uncle sam forgiving in regards to late filings (filed past filing date) when money is owe to them regardless of which type of entity you file under. Usually, there is a penalty of fees they accessed and it is not worth doing. It is easier to spend 5min filing for extention then avoiding not to file. However, I would assume you are talking about in cases where IRS owes you money. Then no, you are right. You may have a few years to file.
The state on the other hand will attempt to calculate your tax returns base on w2/1099 reported to them and determine what you owe them (only if you dont file at all). Once they determine you owe them money. They will contact you directly. However, if deemed they owe you, they won't bother.
SLOW_V is offline   Reply With Quote
Old 01-23-2009   #59
john
Business as usual
john's Avatar
^^ I am a business tax accountant, and yea, the LLC only has expenses this year. I would rather offset the large capital gain I am planning for 2009. I will probably file anyhow to run depreciation on my viper (yes, company car) but still not sure.
97 Viper GTS
Old 01-24-2009   #60
SLOW_V
^^It's pretty cool you are a tax accountant....My job is to logically bullshit and paper push all day. I will look you up if I need any tax advice.
