Old 01-26-2009   #21
Re: Switchin to E-85
Does Corbeau sell brackets for 1gs?
Old 01-26-2009   #22
mdost03
Sonic Champion!
Drives: VA STI
As far as I know, yep.
Old 02-02-2009   #23
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Drives: 90 Talon TSi AWD, 73 Datsun 240z w/Built L28
They must, as i bought the seats with corbeau brackets on them.
cman3000 is offline   Reply With Quote
Old 02-03-2009   #24
jhaan_dude
jhaan_dude's Avatar
Drives: a car
you get that manifold yet? i never heard back in my pm.
Old 02-04-2009   #25
cman3000
Colin
cman3000's Avatar
Im at school now, im sure its at my house. Il let you know when i get home in a few weeks.
Old 02-08-2009   #26
iceminion
iceminion's Avatar
Here are some pictures that I took before I swapped his transmission.
The items of interest are as follows:
My dirty Shep trans.
The unacceptable intercooling.
The wire for the oil pressure sending unit not fully attached.
The exhaust scraping against the driveshaft.
Name:	iphone import 008.jpg
ID:	8206   Click image for larger version
Name:	iphone import 009.jpg
ID:	8207   Click image for larger version
Name:	iphone import 018.jpg
Name:	iphone import 021.jpg
building a 3000GT AWD Turbo.
Old 02-08-2009   #27
iceminion
iceminion's Avatar
All in all the car is very interesting....I guess they build cars different in florida...
for instance, the whole car uses SS lines (even the water for the turbo), but the oil drain is pushlock.
The car is very clean, some redline dripping from the trans/transfer case, oil dripping from the turbo return....
Old 02-19-2009   #28
Why is the pushlock thing baffling to you? Pushlock lines are a lot more flexible than braided stainless. Maybe they just wanted to help ease installation and/or removal? It's not like there is a huge difference between pushlock and braided SS.
Old 02-22-2009   #29
cman3000
Colin
cman3000's Avatar
Well, transmission is in and the car made the trip from Brainerd to Rogers fine. Transmission is great, it is a shep stage 3, but I'm still having some engine problems. The car wont boost much without sputtering, so I am hoping that getting a good tune done fixes everything.
Old 02-22-2009   #30
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Did you try a boost leak test? What plugs are you running and what are they gapped at? Or are you running E85 in it without doing much of a tune at all?
-1990 Mitsubishi Cyborg 4WD-
Old 02-24-2009   #31
cman3000
Colin
cman3000's Avatar
Well DB just did a boost leak test before they put it on the dyno and found 2 small leaks, plugs are BPR7ES but i dont remember what they were gapped to.
Old 02-24-2009   #32
cman3000
Colin
cman3000's Avatar
Should I be running BPR8ES?
Old 02-24-2009   #33
mdost03
Sonic Champion!
Drives: VA STI
The 7's should be fine, they are already one step colder than stock.
Old 02-24-2009   #34
cman3000
Colin
cman3000's Avatar
Even when running over 25lbs of boost on e85?
Old 02-24-2009   #35
When you run too cold of a plug, you run the risk of fouling them out early.
With your turbo at that boost level I personally would not go colder than a BPR7. Hell I wouldn't run 8's on anything that saw a decent amount of regular street driving myself. Why are you wondering about 8's, are you having issues with the 7's being too hot?
Old 02-25-2009   #36
cman3000
Colin
cman3000's Avatar
Nope, just wondering if i should go colder. DB tried to tune today,but the car was running really lean, possibly because of a clogged fuel filter, and they could only get a good run in at 13 lbs of boost, which produced around 225 whp on the DD. After Shane cleaned the filter and was about to make another run at it, the car started to leak coolant out the overflow. Looks like i may need a new headgasket. Damn.
Old 02-25-2009   #37
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
You have to change out your fuel filter about 2-3 weeks after you switch to E85 cause it cleans out your tank. I am running 30psi with my bpr7s's.
Old 02-25-2009   #38
His filter was full of dirt and the main filtering screen was deformed some. The whole internal and screen design of the K&N fuel filter seems a bit cheap compared to something like the Aeromotive units. Even at 13psi it was leaning out too much and I had to abort the runs. I wasn't getting any knock, but with how clogged that filter was it would have been very bad news on pump gas under boost. The misfires he was getting before under boost were probably from it being very lean. There is a good chance that the HG is somewhat blown, since it pushes coolant.
Old 03-10-2009   #39
cman3000
Colin
cman3000's Avatar
Well, did the head gasket, put a custom fuel filter in it, and had shane try tuning it again. The car seems to be hitting fuel cut above 22 psi, but the chip burned for no fuel cut. Shane thinks it is still a programming issue on the chip though. He was able to get the car to do 314 at 22 psi, so once that is fixed i should be at around 400 at 28-30 psi on the DD.
Old 03-11-2009   #40
Nice power, but have you tried putting like a 1.3 BAR radiator cap on there? I was pushing a bit of coolant last summer and it fixed my problem.
