View Poll Results: Does Spaz like the rubber fist?
Yes, possibly multiple fists. 28 71.79%
No. 1 2.56%
Is hiding his fear of vagine by participating in these acts? 10 25.64%
Voters: 39. You may not vote on this poll
Closed Thread
Old 02-03-2009   #301
Re: Does Spaz like the rubber fist?
Originally Posted by RLFebo View Post
I dont think there are too many people on these boards who only have a DSM as a DD.
I do, for the most part I did things the right way and have a reliable car that is pretty fast. Only time my car has really let me down was with the stock headbolts and 21psi, blew the headgasket, but I was asking for it.
asshanson is offline
Old 02-03-2009   #302
311evo
311evo's Avatar
Everyone harasses you about it because if you run into some car on the freeway that wants to have a little fun, you better pwn them epecially if your sportin' style stickers.
otherwise the honda lubers are just going to rage over pwning a dsm.
311evo is offline
Old 02-03-2009   #303
311evo
311evo's Avatar
Maybe because I'm not going to?
I'll concede that you'll win right now, because there's little chance that things will get done before the dyno day.
why not? for one, your car is 10 years newer, i think it would be remotely close.
and why wouldnt it get done in like 2 months time? get off your arse!
311evo is offline
Old 02-03-2009   #304
Plastic ECU, Rubber fist. Anyone else see a similarity in the materials used to make these two products? And yeah, if you think 200HP is gonna blow something up, I think your view of DSMs is a little mis-guided. They're not THAT prone to blowing up. Unless of course you don't know how to check base timing and have it advanced like, 15* or something. haha I don't make the most power in the world with my car, but I've been daily driving it since I got it, and I'm currently making about 300whp. The time has come to drop the skirt, put on a pair of big boy pants, and turn that knob. Hahaha
PS: There's no need to get so upset. We're only messing with you.
Kevin 1G Drummer is offline
Old 02-03-2009   #305
Pretty sure his parents will take away the keys if he mods it.
A//// Guy is offline
Old 02-03-2009   #306
polishmafia
Smells like cat poop
polishmafia's Avatar
polishmafia is offline
Old 02-03-2009   #307
cmspaz
Walls need hugs too
cmspaz's Avatar
It's already modded, just not to any real gain... That aside, my dad doesn't give a damn as long as it stays drivable, and my mom has no say in what goes on in the garage.
Originally Posted by Trogdor
cmspaz is offline
Old 02-03-2009   #308
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Hahahaha, I love it. Your being called out spaz, and not just by me. Better turn up that boost for the dyno run at least lol.
Febo is offline
Old 02-03-2009   #309
311evo
311evo's Avatar
LOL!!
so spaz, where do you get your dresses from?
311evo is offline
Old 02-03-2009   #310
cmspaz
Walls need hugs too
cmspaz's Avatar
You know, I've got a lot more things to take care of on this damn car before I even start putting money into making it faster. Two wheel bearings are bad, one of which is probably a week or so from failing, but I can't afford to fix it, so all I can do is pray it doesn't send me into another car or the wall when it locks up on the highway... And besides that, there's a slowly growing puddle of oil on the cardboard I park over, the source appearing to be where the head meets the block on the front left of the motor, so I've probably got a bad head gasket if not a cracked block now. And to top that off, the new clutch is slipping, because a couple assholes on here told me it was perfectly fine to boost on it during break-in as long as I didn't launch it.
So no, the car's not ready for any more than stock power. Deal with it.
And I've got a question for you, Jake. Where does a kid fresh out of HS get the money for an Evo?
cmspaz is offline
Old 02-03-2009   #311
polishmafia
1 - Finding a job?
2 - He got a job.
Old 02-03-2009   #312
Are you sure the leak isn't from a crack in the valve cover, the drain hole in the valve cover or spray from dipstick? All of which are common causes for oil over there.
Yes, you shouldn't boost, launch or shift quick on a new clutch if it's an organic disc. But if it wasn't/isn't adjusted right that is a more likely cause of slipping. Or if the rear main or tranny is leaking oil onto the disc. Or the clutch is just to weak for your power. Even if you aren't the nicest to a new clutch, they usually don't fail right away.
Shane@DBPerformance is offline
Old 02-03-2009   #313
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
...Two wheel bearings are bad, one of which is probably a week or so from failing.....there's a slowly growing puddle of oil on the cardboard I park over, the source appearing to be where the head meets the block on the front left of the motor....the new clutch is slipping, because a couple assholes on here told me it was perfectly fine to boost on it during break-in as long as I didn't launch it...... And I've got a question for you, Jake. Where does a kid fresh out of HS get the money for an Evo?
Which two? If its rears dont worry about it if its steers then thats bad.
Puddles of Oil are a DSM marking its territory, no matter where it comes from. I doubt you have a cracked block, and why dont you get in there and clean it super good, then check again in a few days, maybe its coming from the VC.
and when you get some time, pull that clutch and deglaze it, it should still be good
Also, dont hate the player, hate the game.
Febo is offline
Old 02-03-2009   #314
cmspaz
Walls need hugs too
cmspaz's Avatar
Valve cover leaks a small amount from that corner, but the oil on the block is fresh, versus the oil on the head that is not, so that would rule out the drain as well. I've also never blown out the dipstick.
Disc is kevlar, and they're more prone to glazing. It once held 13 psi in all gears, now it won't hold anything above 10. So I'd say a 2100lb clutch that isn't holding even 200ft-lb at the crank is cooked.
Febo, it's both fronts that are bad. I already had to do both rears this past fall.
cmspaz is offline
Old 02-03-2009   #315
Warranty that clutch and the work to install it then, that's unacceptable.
scheides is offline
Old 02-03-2009   #316
Do you have free play at the top of the clutch pedal? Does it engage low/mid/high?
Old 02-03-2009   #317
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Junk yard some new hubs and buy yourself some time? Im sure if you go to st. francis salvage you could pull em, and toss em over the fence lol
Febo is offline
Old 02-03-2009   #318
Call up Curt Brown and get some of the ceramic wheel bearings he is running.
Old 02-03-2009   #319
cmspaz
Walls need hugs too
cmspaz's Avatar
The issue being that the work was done by Mitsu, who said they couldn't make guarantees on it. Whether that covers workmanship, I have no idea, I'd assume that if it doesn't I could easily fight for it if something was done wrong.
So you're saying to invoke the warranty through Comp Clutch, and that it should cover both labor and parts(if disc replacement is necessary)?
I'm 100% sure it's my fault because it used to hold, and now it doesn't. Doesn't mean I'll tell that to anyone calling the shots on the warranty, but still...
Clutch engagement is the same it's always been; right at mid, always the same spot.
Ceramic wheel bearings? Sounds interesting. I'll look into that.
cmspaz is offline
Old 02-03-2009   #320
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
If you cant warranty it and the disk is just glazed along with the Pressure plate, then just take some 1000 grit sandpaper and lightly scuff them to take off that glaze, as long as it didnt eff the disk too much you should be good, maybe this doesnt work for clutches, but Id think its worth a shot. lol
Febo is offline
Closed Thread
