Old 02-11-2009   #21
Re: Swifty's never-ending project thread!
I fuking told you I have a camera you can HAVE! It was sitting in front of the microwave and anna hit the button to open the door and thwack! cracked went the screen. It still takes pics just fine. Rosey has the charger for it, or you can buy your own for a few bucks. It's got a small SD card in it, but those are cheap as hell ($10 @ microcenter)!
Old 02-11-2009   #22
ya ya ya...i suppose. if peter shows up give it ho him and then he can give it to me.
Old 02-11-2009   #23
Shows up to what?
Old 02-11-2009   #24
bees. im still waiting on john.
Old 02-11-2009   #25
Are you drunk? Wtf are you talking about?
Sure, I'll give it to peter...ummmmm ok.
Old 02-11-2009   #26
Reading this thread makes me want to ban Swifty right now.
Old 02-11-2009   #27
not drunk..peter was going to stop by to bees tonight before coming out to fridays..so there!
Currently, the car is bumperless, timing belt less, fuel injectors, and etc. John is redoing wiring and moving the MSD, fuse box, and mocking/making my 3" upper ic pipe. I ordered a new red tial wg, got my electric exhaust cutout, and then i gotta put it all back together. JMF DRAG manifold is on the car, but for mock up. The new q45 tb i got i can actually fist..it's serious. So, that's the plans/car as of right now. Once done, it's tuning and paint.
-A. Swift
Old 02-11-2009   #28
-A. Swift
There, was that so hard? Who know John was doing work for you? You mean Pushit2.0?
Random half-tidbit comments = fail
details = win!
please continue.
Old 02-11-2009   #29
yea, pushit is. I HATE HATE HATE wiring, so he is doing it. And, I can't weld aluminum, so there ya go.
-A. Swift
Old 02-11-2009   #30
Wow, my head hurts.
Old 02-12-2009   #31
So you are actually going to fully assembly and wire in everything this season?
The 500+ you made last year at 24psi wasn't that bad at all considering the issues you still had and well...how the car was put together. A little polishing and tiddying up loose ends and you should be good to go this season.
I already told you the AEM can comp for changes in afr if that wideband is wired into the aem and calibrated correctly (as well as accurate). It is the octane swings related to timing that I was worried about (as Shane mentioned above). In the end its your car and whatever makes you happy.
Post up completed pictures when you are done.
Old 02-12-2009   #32
Check it out swifty! I can post the pics you emailed me, like magic!
Click goadvanced to reply,
then click 'manage attachments'
then pick the files I want to upload (I saved your pics to my local computer!)
Then once they're uploaded, you can either just leave them be (thanks to the new nifty shadowbox feature)
OR you can right click on the links to the images and copy the link, slap it between some IMG tags and you're set:
Add some comments like:
"Progress pics. manifold off. fuse box m s d and etc removing and relocating. cam gears installed. pipes mocked up. etc.
-A. Swift"
And you're set. Please continue
ID:	8222   Click image for larger version
ID:	8223   Click image for larger version
Old 02-12-2009   #33
Whats with all the heavy SS braided lines? What size are those catch can breather lines?
Old 02-12-2009   #34
-6
Old 02-12-2009   #35
ylimert01
ylimert01's Avatar
Drives: Nissian
wow I had a headache before reading this thread and now I have a migraine..good luck with project hope it makes it to the dyno day!!!!!
F Subarus!!!
-Emily
Old 02-12-2009   #36
~8 actually. it was the catch can pff maps rxfdsm thing. sheides can you clean ip the thread a bit so i dont get a headache?
Old 02-12-2009   #37
OMG! pictures!!! Still want that mojito? lol
Old 02-13-2009   #38
This thread sucks, haha.
the bigger the catch can lines, the more oil it can catch.
Old 02-13-2009   #39
yea, but higher boost will raise crankcase pressure..look what happened to the RX7. Hence why they needed a bigger can. MY can hasn't been filled much at all, and I remember what happened with the old can and NO vent hole or filter for it..wow..smoke like no other! This seems to work well for me.
I got the exhaust cutout today, and the WG should be here soon. Sat, John will come back over to continue the wiring process, check grounds ( must be a wiring issue, as to why it didn't rev last year) and to degree the cams.
-A. Swift
Old 02-13-2009   #40
Looking good!
