Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 02-23-2009   #1
evo turbo stuff
exhaust manifold gasket (to head)
exhaust manifold gasket (to turbo)
o2 housing gasket (from turbo)
bolts, manifold to turbo (x4 please)
oil feed banjo bolt copper washers to head (x2)
oil feed banjo bolt copper washers to turbo (x2)
oil drain tube gaskets (both sides)
coolant feed and return hoses (rubber ones)
coolant banjo bolt copper washers to/from turbo (x4)
Also those stupid push-pin clips for the trunk lining (x15)
If you could note the part numbers and price for future use here, that'd be awesome, otherwise just order it all and LMK when it comes in.
Old 02-24-2009   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: evo turbo stuff
manifold gasket mr323654 $21.38 in stock
turbo gasket 1515a184 $33.28 need to order
o2 gasket mr299686 $9.70 in stock
manifold to turbo bolts mn119783 $2.74 ea x4 need to order
oil feed washer to head mf660063 $1.02ea x2 in stock
oil feed washer to turbo mf660064 $1.22 x2 in stock
oil return gasket mr258477 $1.16 need to order
oil return gasket 1226a002 $1.52 need to order
water feed hose md363256 $3.34 need to order
water return hose md082347 $3.16 need to order
coolant washers mf660065 x4 $0.72ea in stock
trunk clips mr975477hc $1.82 in stock
thank you!!
Nick
LUTHER BROOKDALE MAZDA MITSUBISHI
763-503-4695
nick.galbreath@lutherauto.com
http://www.facebook.com/#!/Luther.Auto.Dealerships
http://www.Lutherauto.com
Nick G is offline   Reply With Quote
Old 02-24-2009   #3
Re: evo turbo stuff
Slight modification:
turbo gasket 1515a184 $33.28 need to order *bends over* ok.....do it!
manifold to turbo studs mn119784 $7.34ea x2 need to order <--SKIP
manifold to turbo bolts mn119783 $2.74 ea x2 need to order x4, I'm going to replace the studs!
water feed hose md363256 $3.34 nee to order
thank you!!
Nick
Also you forgot the trunk clips, can you get those too please? Can I get all this stuff by friday?
Old 02-24-2009   #4
Re: evo turbo stuff
72858B x15 for the trunk clips
Old 02-24-2009   #5
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
Re: evo turbo stuff
done deal
Ill pm when in
thank you!!
Nick
763-503-4695
