Old 03-30-2009   #181
Re: My Talon
engine bay looks way good! you paint the bay?
Old 03-30-2009   #182
Re: My Talon
Glad to see I'm not the only one with "modified" thermostat housing wiring. Looks good man!
ha yeah I got sick of the broken connectors, so I added some new wires and new spade connectors.
Old 03-30-2009   #183
Re: My Talon
Originally Posted by blackrosenova400 View Post
I have two solid lifters, I will be degreeing my BC 280's. Do you have adjustable cam gears? I think we should spend a day degreeing them if you do, although I think it would be alot harder with the motor in the car.
I do not have adjustable cam gears, but I'd love to learn the process of degreeing cams.
Old 03-30-2009   #184
Re: My Talon
I rattle canned it black last fall, filled in a lot the holes in the firewall and other places. I like the way it turned out. I did prep the bay very well as well, engine was out, cleaned, sanded and primed, etc. Some people hate it, some people like it.
Old 03-30-2009   #185
Re: My Talon
Dude, I wish my engine bay was as clean as yours its lookin awesome!
Old 03-30-2009   #186
Re: My Talon
Still waiting for Fedex to bring me a present! The car is in an un-heated garage so with this crappy weather I might not be feeling up to finishing the last little bit of stuff till it's in the 40's again.
Old 03-31-2009   #187
Re: My Talon
Just showed up this morning:
My Asus Eee PC Netbook! I already have Link V3 on there ready to go!
This thing weighs like 3 lbs with the 6-cell battery. It's tiny! I like the multi-touch touch pad. It has a N280 processor (1.66ghz, the fastest you can get right now), wireless b/g/n and bluetooth, 160GB HD, 10" screen, and it boots Windows XP really fast! I got this just for link lol, and internet browsing.
ID:	8394   Click image for larger version
Old 04-04-2009   #188
Re: My Talon
Installed my oil cooler, made my -8 cooler lines. I need to install Link, empty and fill tank.
Old 04-05-2009   #189
Re: My Talon
Started the car today. Won't idle Still on 92 oct, no fluid leaks anywhere
Old 04-05-2009   #190
Re: My Talon
Thanks to Brandon (Halon) for some over-the-phone troubleshooting. He helped me fix a few problems I didn't even know I had.
Old 04-05-2009   #191
Re: My Talon
No problem. Hopefully you get some more of that figured out. I guess I'm just not an expert when it comes to calibrating GM MAF applications. Mitsu MAF's for life
I hope you get it all worked out though, because I'm anxious to see what that thing puts down!
Old 04-05-2009   #192
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: My Talon
What ended up being wrong that it wouldnt idle?
Amsoil Dealer
Old 04-05-2009   #193
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: My Talon
Ya is there anything that I should know that we overlooked??
Also, how is it running now?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-05-2009   #194
Re: My Talon
Thanks to Aaron (turbotalon1g) and Nick (munchgsx) for coming over and helping with the trial and error that eventually got my car idling! woohoo! Now the real tuning can begin.
I had to adjust my MAFComp +50% across the board to get the car to idle and be at a normal, stable A/F. It was just dumping gas at idle.
Old 04-05-2009   #195
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: My Talon
I thought you said you're wideband was showing full lean?
-1990 Mitsubishi Cyborg 4WD-
Old 04-06-2009   #196
Re: My Talon
Good to hear!!!
Old 04-06-2009   #197
Re: My Talon
Adding 50% to the MAFComp table doesn't make any sense. Something else is way off or broken to need to do that across the board. Having to add 5-25% in the 50hz/idle column is common with MAFs that don't meter the best at idle or are hacked, but having to add a 50% is a lot and weird to have to add anything near that in the 150hz+ columns.
Old 04-06-2009   #198
Re: My Talon
I've read that the GM maf's require a lot of adjustment. The car idles at 500hz lol.
Old 04-06-2009   #199
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Re: My Talon
Any chance you're driving this to come pick up the fuel sending unit? I'd like a ride! There is a perfect straight road about a quartmile a block from my house too. lol
Old 04-06-2009   #200
Re: My Talon
haha maybe, most likely not, but maybe next week
