Old 04-08-2009   #41
Re: Cylinder head noise!
I may not know everything but I am almost ase certified master tech so I have a pretty good idea of what I'm talking about and I'm just going off of what they teach us in school. in my notes I just wrote down replace cams replace lifters. but thinking about it it makes more sense for flat tappet lifters. I'll double check with my teacher and see what he says but I definitely know how to diagnose engine noise and it is in the cylinder head. at least I'll be rather suprised if it isn't
*checks his ASE Engine Repair Cert*
*checks his ASE Engine Performance Cert*
*checks his multiple years of tuning and Mitsubishi specific experience*
You sir are thinking of flat tappet lifters and lifters in the pushrod sense. HLA's (Hydraulic Lash Adjusters) are typically replaced only in a noise complaint or bleed down situation (or to increase RPM range/adjust for ground down camshafts).
I agree that HLA's are a good idea to swap out as they are old, but it is not required.
GSXBoy-
Have you checked your cam followers? It could be a bearing going bad/flat spot on one of the cam followers (or as others would incorrectly call them, "rockers") How are the cam's wearing in? All the head oil flow passages clean?
Old 04-08-2009   #42
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
GSXBoy-
All that I did was check and see if there was any play in the rockers.. and the head oil flow passages seemed to be clear. I did not notice any flat spots in the rockers...
Like I said this was not there last year when I parked it so something went bad along the lines of installing new cams, timing belt, and arp's
Kyle from map said that when you put mor aggressive cams in that if the lifters are worn in to a certain point and then you put in say, bc 272's then the lifters have to lift more and the spring is not used to that...
Besides, I had lifter tick not this winter because it was parked but the winter before hand the lifters would tick pretty good upon start up so I'm thinking that this was enough to push the lifters over the edge
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-08-2009   #43
GsXtUrBo98
GsXtUrBo98's Avatar
Originally Posted by deadeye View Post
Anyways, I look forward to hearing what the problem is. I would almost be willing to put money on a lifter(s) or possibly a cam bearing(s). If anyone can figure it out its MAP. Sometimes the pros just got to take over and do work.
I agree and or when your just fed up with all the bull shit then let someone else fix it. I just dont like other ppl working on my car... But thats just me.. even though they are pro's
When I come down to this if its the rod baring then 6 bolt swap time!! I just dont know if I can afford the built one at the moment like I want to do... Kevin ( sleepydsm ) is trying to convince me to do a 2.3 stroker.. I was just planing on doing a built 2.0 but we will see what I can do. I might only be able to do a stock rebuild for the time being but I hate to do the swap and not go all out the first time....
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #44
Little tidbit for ya: the 4g63 has no cam bearings.
Old 04-08-2009   #45
GsXtUrBo98
GsXtUrBo98's Avatar
I didn't want to seem stupid but I was gonna say what bearing are you talking about... lol
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #46
brando
Drives: gutlass
did you use oil when you put the lifters in?
Old 04-08-2009   #47
GsXtUrBo98
GsXtUrBo98's Avatar
didnt put lifters in
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #48
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
GSXBoy-
Sorry, this is what I was thinking of when I said that. I guess I dont always say what I mean sometimes.
Anyway, I understand you not wanting someone else to work on your car. MAP is the only one besides me that has touched my car. I guess I have known the crew there for a really long time and trust them with anything I got if I cant figure it out or have the equipment to do what needs to be done.
deadeye is offline   Reply With Quote
Old 04-08-2009   #49
mike55112
mike55112's Avatar
Drives: 04 evo
Do built 2.0 now.....
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 04-08-2009   #50
GsXtUrBo98
GsXtUrBo98's Avatar
Well I just got the call from map and it turns out that my cams have back and forth play when everything is tight!!!... they said either the cams were miss machined or the head is fucked.....
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #51
deadeye
deadeye's Avatar
Bummer dude! I would be hoping that its a case of the cams being bad. At least then you could maybe get away with some warranty claim stuff. PITA but at least you wouldnt have to end up paying for it...
Old 04-08-2009   #52
GsXtUrBo98
GsXtUrBo98's Avatar
Pita?
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #53
pita = pain in the ass
Have them try some stock cams in there to see if the head is bad, otherwise send those new cams back on warranty. Maybe the caps were put back on in the wrong order?
Hopefully it didn't mess up the cam bearings ... err I mean journals haha.
Old 04-08-2009   #54
GsXtUrBo98
GsXtUrBo98's Avatar
He said there were no scaring and the caps were put into an order af how they came off and thats how they went back on..
They are going to check the cams and if they are bad then obcourse get new one's under warranty considering they have 1 mile on them..
Bought them from map.. but they said mostlikly it will be the head..
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #55
Has the head been machined? Who did the machine work?
This started to happen after you swapped the cams? Was the head pre-existing?
By movement do you mean walking side to side in the head or movement as in the cams slide around inside the cam caps?
Weird shit either way.
Old 04-08-2009   #56
GsXtUrBo98
GsXtUrBo98's Avatar
the whole engine war remaned and its got 40k on it.. all i did was swap the cams and they told me that he could take his hand to it and force it back and forth while it was all clamped down and torqued..
as in twards the back of the car and twards the front of the car side to side play but mostly on the exhaust one
98 GSX (built)
03 BBY EVO dd
Old 04-08-2009   #57
4seasons69
4seasons69's Avatar
GSXBoy-
thanks for correcting me. I'm still in school and it's a lot of info to take in and I sometimes get little details mixed up.
Old 04-09-2009   #58
GsXtUrBo98
GsXtUrBo98's Avatar
Well the noise has pin pointed and I'm going to start a new thread..
98 GSX (built)
03 BBY EVO dd
