Old 05-10-2009   #1
DIY LICP & Buschur Race FMIC install
I picked up a new FMIC for my evo last week and wasn't prepared to pay the $289 buschur charges for the LICP that is needed for this specific FMIC. Not sure if its due to the size or what, but the inlet is not in the standard position. I had some extra aluminum piping from a project on my brother's 1G, and everything looked like it would be pretty easy to fit together and cut for my needs.
Just thought I'd document this in case anyone else is interested.
Parts List:
1x Buschur Race FMIC retail $799
1x 2.5" aluminum pipe 180° bend w/ 6" legs (Vibrant Part # 2867) (free)
1x Silicone Reducing Elbow - 45 degrees (#ASRE45-X from boostcontroller.com) $38
3x 2.5" t-bolt clamps (#288 - boostcontroller.com) $4/each
1x 1.8" t-bolt clamp (fits stock oulet pipe perfectly!) (#225 - boostcontroller.com) $4
First, some FMIC pics! BR Deluxe on top, new 'race' core on bottom.
Kinda makes the old one look small. When I bought it, it was the biggest one you could get!
Now, mocking up the LICP:
The plan is to cut along the black line:
Then, a second piece to make the long leg end over to the turbo outlet pipe:
(careful, aluminum crushes easily!)
This was the original plan:
But then, as I looked at it, a second option presented itself. The coupler from boostcontroller.com was much longer than I had anticipated, and I had planned on just cutting it to size. However, check this out:
It fit perfect, I could not have planned it better. I had planned on getting that extension pipe welded onto the long leg of the j-pipe, or simply running a coupler in the middle of the straight section. With as well as this fit, the idea of not having to deal with getting the thing welded (i.e. more $$) or more couplers (meh) started to look not so hot. That, coupled with the fact that every welder I talked to didn't really want to weld this cheap piping, which helped me make up my decision.
Fully mocked up:
Test fit w/ bumper:
Side note. Buschur Race FMIC can fit behind the stock crash bar with ZERO trimming. I bent one bracked on the crash bar flat and that was it. I put some 5mm spacers between the crash bar and the frame. If you have time, get some extra long bolts from your local hardware store for this, but otherwise I got the stock ones to fit with some fiddling.
I cut up a silicone coupler and stuck it between the crash bar and the FMIC to avoid rattling or rubbing. This fit without a problem:
Final LICP parts. DB Performance in Rogers, MN has a bead roller, and they rolled beads into this J pipe for me.
Done and done:
I went ahead and put my stock FMIC in place to see how this design would work. Looks like it should fit no problem, just cut the J-pipe a little different, and it wil fit in the couplers a little more level than with my buschur race FMIC:
Done:
The next day I made 394whp on a dyno dynamics with my BBK and this new setup. It seems to work well The stock outlet pipe is 1.8", then transitions to 2", then the 45° bend, then immediately opens up to 2.5". I might be contacting boostcontroller.com to see if they would make a custom coupler that has the 45° in 2.5" instead of the 2" section. Other than that, I'm very happy with this setup!
Old 05-10-2009   #2
Re: DIY LICP & Buschur Race FMIC install
How close is that long silicone coupler to the downpipe? I would try putting some heat wrap on the downpipe, to prevent it from damaging the coupler maybe?
Old 05-10-2009   #3
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Lookin good!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-10-2009   #4
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
looks really good! Glad to see you made some good powa finally!!!
Old 05-10-2009   #5
I'm glad the LICP came together so easily!
Old 05-10-2009   #6
looks really good. a lot better than buying to for a ton of money for a simple pipe
Old 05-10-2009   #7
I kinda thought the same thing, but it was no different than before; the LICP goes right past the downpipe. If it ever is an issue, I'll address it.
Old 05-10-2009   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Very sexy. Thought I noticed something a little more shiny behind you're grill. So was the old IC the cause of you loosing power?
-1990 Mitsubishi Cyborg 4WD-
Old 05-10-2009   #9
To be honest, I'm not really sure. I have hardly driven the car with the new FMIC on, but it does feel good!
Hughes thinks it was actually the new driveshaft bushings he helped me install a few weeks back, while I'm convinced it was the new transmission fluid (kidding). :P
The car is still pushing coolant under high boost, I'll post more info as I figure it out
Old 05-11-2009   #10
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Didn't you just reciently do a new HG?
Amsoil Dealer
Old 05-11-2009   #11
yup, last fall. Oil burning has continued to get worse since then and now its pushing coolant again. I'm going to yank the valve cover and re-torque the headstuds just for good measure, but not sure what the deal is.
Old 05-11-2009   #12
95talonracer
Finally Tuned...
Drives: Spyder GSX
What HG?
Amsoil Dealer
Old 05-11-2009   #13
A new stock one, Mitsu MLS. Got head machined flat at the time it was off too.
Old 05-11-2009   #14
I think you have TMP. Better convert back to stock.
Old 05-11-2009   #15
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Time for some L19's!
Old 05-11-2009   #16
TMP?
Hrm, might not be a bad idea....shouldn't need them tho....
Old 05-11-2009   #17
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
True but then you'll never have to worry about lifting the head ever again!
Old 05-11-2009   #18
He means too much power I think
Old 05-11-2009   #19
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I wanna see a 400whp dyno graph!
Old 05-11-2009   #20
Looking good.
I personally like using those long leg couplers. I'm sure from a purely performance perspective, some may say they aren't ideal (mandrel bent hard piping may be superior), but they make the fitment of everything so much easier in my opinion. And for me personally, finding a good balance between performance and fitment is important.
Setup gets a thumbs up from me
