Old 06-01-2009   #21
Re: My summer project - 1995 Polaris SLX 780
The parts cost is already adding up! I've spent about $120 already buying maintenance and replacement parts and I haven't even begun actually working on it.
Old 06-01-2009   #22
Nice project! I had a '95 Yamaha Waveblaster 700 with a few mods. That thing was a lot of fun! Seeing this makes me miss it.
They are fun toys! Ever since my modded '94 Polaris SL650 blew up I've missed having two around. My parents have a '01 Polaris Virage so it will be nice having two at the lake again.
Old 06-01-2009   #23
Nice, I had a couple of vintage SL650's as well, great ride for the price. I thought about slapping a turbo on it, then read up on two-stroke's, no thanks.
Old 06-01-2009   #24
Turbo two strokers can make a decent amount of power, they are just a pain in the ass to set up.
As far as using a DSM to tow a boat, I think the boat in the pic would be a little too heavy for me to feel comfortable with. I used a '93 Celica to tow my jetski and it worked just fine.
Old 06-03-2009   #25
I wouldn't worry about a boat behind my DSM since it's beefed up in every way, but I wouldn't want to be putting the rearend in the water every time I launched or pulled out the boat. Trucks that frequently load and unload boats go through rear bearings quicker.
Old 06-06-2009   #26
I spent a good 8 hours today working on this thing. I replaced most of the fuel lines (10' wasn't enough so I ran out today), removed the jet intake grate to clean out the jet pump, put in new spark plugs, sprayed the carbs with some carb cleaner, drained the oil and fuel, inspected and cleaned the reeds, lubricated the steerting, throttle, and choke cables, tightened the steering and trim connections, refilled the oil and fuel with fresh stuff, replaced the fuel and oil filters, and finally primed the fuel system. If I work on it again tomorrow I'll finish replacing the fuel lines, clean the flame arrestors, reattach the intake manifold and carbs, and maybe get a new battery for it and try turning it over
Old 06-06-2009   #27
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Sounds like you know what you're doing!
Style's automotive engineer
Old 06-07-2009   #28
Good progress.
You will probably need to take the carbs apart and clean them. Just spraying carb cleaner wont do much.
Old 06-07-2009   #29
You're probably right Do you think a carb rebuild kit will be necessary?
Old 06-07-2009   #30
Unless you wanna spend hours cleaning every tiny little part, I'd suggest getting a rebuild kit. You would probably need to buy gaskets for it anyways.
Old 06-07-2009   #31
cmspaz
Walls need hugs too
cmspaz's Avatar
Yeah, just rebuild them, and buy yourself carb cleaner in a bucket, so you can fully submerge and soak the non-plastic components once you get them disassembled.
Originally Posted by Trogdor
Old 06-07-2009   #32
Damn them for not using Stabil 4 years ago!
Old 06-07-2009   #33
Haha even stabil wont stop all gumminess in carbs. I had to clean/rebuild by bikes carbs this year, did it 2 years ago too. Passages are so tiny that gas in the carbs just gets gummy.
Rebuild kit isnt a bad idea, the rubber gaskets are probably all hard, may leak if taken apart and put back together.
Old 06-08-2009   #34
Once they are out Chris you might as well rebuild them, it's cheap and then you won't have to worry about your high speed jet not working right, running it lean, and burning it up in the process. Plus rebuilding those older carbs isn't very hard. Another thing I would strongly suggest checking out in the oil injection system, I have heard of those having problems if they sit a long time. Looks like a cool project though.
Old 06-08-2009   #35
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
Not a bad machine, I have a 1995 seadoo hx with minor mods. Definitely fun summer toy but they are maintenance whores!
Jungy is offline   Reply With Quote
Old 06-08-2009   #36
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I would say definetly rebuild the carbs and fuel pump as they are more then likely all gumed up and dried out.
Amsoil Dealer
Old 06-20-2009   #37
Well, everything is ready to attempt starting the engine, just waiting for the new battery to charge
Scheides' lended a hand today and came over (well, I picked him up) and assisted in getting the carbs/intake manifold bolted back on and finish replacing the fuel lines.
Old 06-20-2009   #38
I successfully lost one nut and one bolt! Glad I could help!
Old 06-21-2009   #39
No go I drained the battery and a can of starting fluid with no success. As 95talonracer said, the carbs and/or fuel pump probably need rebuilding. It is getting spark though which is good. The engine was so rusted solid it wouldn't even turn over at first. It took a lot of quick repeated start button pushing to finally get the internal rust broken free. Once it started turning over though it sounded really strong which got my hopes up. I was trying for a long time though, I'm impressed with the $50 Walmart battery.
Old 06-21-2009   #40
Hopefully the cylinder walls and bearings aren't messed up from being slightly seized up like that.
