Old 06-13-2009   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
20 psi on stock 4g63t ?
ok been getting used to the laser for the last few weeks with the big 16g on there and i cranked it up and some how im hitting 20 psi im normally running 15-16 psi I am not getting fuel cut ... except when the check engine light comes on and then stays on untill i reset the computer im running 92 + octane boost would like to know whats causeing the light to come on
as far as i know the car still has 450 they are blue top injectors i dont know whats been done to the head but i know this i get loose traction when i get in to boost in 2nd gear then rockets to 90-100 all i hear is air moving
... i just turned it down to 16psi tonight affter running around
i dont know if any of u guys were out at sun foods and see it ...
is my boost gage lying to me ? i thought its not possible to push 20psi on a stock fuel system i allso think my 02 senor is bad i run really ritch i can smell fuel when im at a stop but ritch is better than lean ... id run a wideband if i could to see what im acutllay running
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 06-13-2009   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: 20 psi on stock 4g63t ?
Oh it's possible to run 20psi on the stock fuel system, there is nothing stopping you. It's just a really, really shitty idea.
Old 06-13-2009   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Were you in the red laser?
Old 06-13-2009   #4
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
your ecu is compensating for your boost and that could be the reason why your CEL goes on.......if i read it correctly..
anyways, you shouldn't boost that much without much mods if you're just stock. Boost is addictive but do it the right way. I haven't seen many DSMs around Uni...that or they have no clue what I'm driving. *sighs* well, how many miles do you have on it?
ლ(ಠ益ಠლ)
Old 06-13-2009   #5
Constant_Project21
Drives: E36
Didn't see any galants last night, handful of 1gs, couple nice 2gs, but vividly remember a red laser doing a pull out onto university, while a cop was passing. Damn lucky they didn't get ticketed.
Old 06-13-2009   #6
cmspaz
Walls need hugs too
cmspaz's Avatar
CEL I'm guessing is something along the lines of fuel trim malfunction. You get it when the ECU is trying to adjust fuel maps past the 12% is allowed to adjust them to compensate for the excess airflow.
The stock fuel cut level is really generous, and the fuel pump can fairly easily handle 20psi to redline. But with stock injectors? Don't push your luck. I wouldn't go past 15psi max.
Originally Posted by Trogdor
Old 06-13-2009   #7
Constant_Project21
Drives: E36
Yea throwing 20psi at stock 450's with a 16g doesnt sound like a good idea at all. Can only imagine what duty cycle theyre running at, or if its leaning out hella bad.
Old 06-13-2009   #8
twack
It was a auto get over it
twack's Avatar
Ive done it and it ran awesome.....
Till i got lucky and ONLY melted my sparkplugs!
Old 06-13-2009   #9
Gravy
Who's this guy?
I would be cautious, i've seen people do it, but your running your injectors overtime to do so. SAFC and 550's and run it at 20 all day long with no problems.... pump may need and upgrade.
Old 06-13-2009   #10
lucasoil4u
Drives: talon tsi evo 3 25psi
just upgrade the injectors and get a safc and call it a day. the stock pump should be able to handle 20 psi. dont do a walbro until you need it. The injectors are just open probably.
Mitsubishi.... Special Cars for Special People.
Old 06-13-2009   #11
Not on a 1G. They only throw CELs when something is broke broke. Could be a general CEL for failed O2 sensor though.
The stock injectors will support enough power for just about any 14B and a many 16G cars, but they can't do it without a modified ECU. You will hit fuel cut or the stupid IPW cap that the factory ECU has before you make full use of the injectors.
Old 06-13-2009   #12
way2fastalon
IS Broken :-/
yep
+more mods to list
Old 06-13-2009   #13
way2fastalon
IS Broken :-/
yeah that was me ..lol
+more mods to list
