Old 07-28-2009   #41
viridionplague
Re: E85 Injector Issues... Anyone?
gasoline cleans them up
Old 07-28-2009   #42
I haven't pulled my injectors yet, but I HOPE to be cleaning the fuel filter out at work tomorrow..we shall see.
Old 07-28-2009   #43
viridionplague
just gonna add this in quick, i bought some injectors used for e-85, and got that gunk build up, cleaned them the best i could with cotten swaps and some cleaner, they came out ok, but i ran gas through them for a little while now there spotless
Old 07-28-2009   #44
I won't have gas going through mine at all..not going back, nor do I even have a tune for it. So, now can I pull them, clean them, then put back?
Old 07-28-2009   #45
viridionplague
well its just an option, you could pull them, clean them the best you can, and soak the tips in gasoline for a bit, should work out i would think, i dont know what it is specificaly that actualy causes gas to clean them though.
Old 07-28-2009   #46
blackrosenova400
blackrosenova400's Avatar
I degreed my BC 280's, it was a bitch but I seem to pull 2-4 more inches of vacuum at idle, than anyone else. Powerband seems to start around 4000-4200 rpm.
The fact that anyone advertises cams as drop in, is a farse.
its sad, but most people don't even degree their cams..it's just thrown on stock gears, and buttoned up.
-A. Swift
Old 07-28-2009   #47
my bad......delete this post
Old 07-28-2009   #48
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
My PTE1200's were covered in that black tar resin shit. They had about 12K miles on them pretty much always using Holiday E85.
A couple of minutes with carb cleaner and a pick and they cleaned up nice.
Old 07-28-2009   #49
Gravy
Who's this guy?
Have any of you guys run seafoam though the car(or other fuel injector cleaner) on a semi regular basis? Wondering if the people not getting the build up may be using something that cleans it up, and those that are getting it don't use a cleaner.
I havn't been running said injectors, but i had some 550cc RC injectors running E-85 all last year. Mine were spotless but i switched them out to run gas this summer on 450cc injectors due to idle issues. Will be going back soon i think, but now worried about this black goo.
Old 07-28-2009   #50
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I had 45,000 miles of only E85 and almost 3 yrs on my PTE 1000cc injectors and only two of the injectors had very small trace amounts of black gunk, the other two were perfrect. A cotton swap and small amount of carb cleaner removed it almost instantly. I'll have to pull my FIC bluemax 1250cc injectors at the end of the summer to see if they have anything.
I mainly fill up Holiday on Foley in CR or Holiday on 96 and 35W.
Old 07-28-2009   #51
Mine were clogged so bad they didn't squirt fuel and two cylinders didn't even run. Soaked the tips in maybe 1/2 oz gasoline in a plastic cup and the gas was black within 20 minutes, got new gas for a few minutes and came out clean, the tips were like brand new.
I wouldn't take the time with carb cleaner and a swab, just let them sit for a few minutes in gas.
Old 07-28-2009   #52
I'll give this a whirl.
Old 07-28-2009   #53
Careful to just soak the tips. I accidentally had a bit too much gas and the bluemax paint started peeling off the sides of the injectors
Old 07-28-2009   #54
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Same place I do.
I guess it's more prevalent with the 1200's
Old 07-28-2009   #55
^^Oh sweet, so glad I got some now lol
Old 07-28-2009   #56
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Me too
Old 07-28-2009   #57
I've yet to find any black goop on mine. I don't do anything special like run Seafoam or anything. I've just been lucky so far I figure.
Old 07-29-2009   #58
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
I have a set of Deatschwerks 1600's I got from AMS and put almost 250 miles on them and all were clogged up with the black tar like substance, so I'm guessing it had nothing to do with the injector itself, but the E85 that I put in the car.
One of the cylinders was lean as hell, piston, valves and spark plug were pure white.
As far as cleaning them I just used a can of electronics cleaner, one quick spray and all was like new again.
Mwolf83 is offline   Reply With Quote
Old 07-29-2009   #59
I soaked the tips in gasoline, and literally within like 10 mins they were clean. I guess us E85 guys might need to run a tank of regular 92 once every few months?
Old 07-29-2009   #60
That's what a lot of the link guys have said. Just run the tank really low, put in a few gallons of regular, then back to e85.
