Old 10-10-2009   #1
twack
It was a auto get over it
twack's Avatar
help getting running after auto to manual
almost done with my auto to manual swap. The car powers on but when i turn the key i get nothing. no cranking, no fuel pump turning on. I have the brake and clutch sensors that are next to each other hooked up. the sensor on the back of the clutch pedal is not plugged in and im not sure where it goes to. Not sure where to start but any help would be awesome.
Old 10-10-2009   #2
Re: help getting running after auto to manual
IIRC, the top clutch pedal sensor is for the cruise, the bottom one is your ignition safety sensor, that can stay unplugged.
The fuel pump won't turn on with the cam sensor noticing some movement. You can use the jumper right by the fuel filter to test that the fuel pump comes on.
Do you have the ignition wire hooked up on the starter?
Old 10-10-2009   #3
twack
twack's Avatar
i have the starter wire hooked up. on 2gs i know you need to jump the neutral safety switch, but im not sure how or if i need to on a 1g
Old 10-10-2009   #4
Ronnie S
You need to simulate that the car is in park or neutral I would think. I'm not familiar with the 1g auto but on other cars, you need to ground the park signal and or neutral to activate the starter relay.
Ronnie S is offline   Reply With Quote
