Old 10-22-2009   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Engine Woes - Dong Dong Dong Dong
What would be the cause of the engine making a dong, dong, dong, dong, noise? It sounds like it echos and it is in tune with revving the engine. I'll get sound/video later, but wanted to know what it could be in the meantime.
Avatar = Small Turbo:confused:
mukapahnpy is offline   Reply With Quote
Old 10-22-2009   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Engine Woes - Dong Dong Dong Dong
Did you check your crank pulley?
Old 10-22-2009   #3
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Crank pulley is good. It is still in good working condition. Another ear thinks it is the turbo. The sound appears to be originating above the exhaust manifold and to the passenger side of the cylinder head. It really sounds like dong, dong, dong, dong.
Old 10-22-2009   #4
Chinese midget?
Old 10-22-2009   #5
LOL^^^^
no those go ching chang chong
Old 10-22-2009   #6
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Rod knock.
Amsoil Dealer
Old 10-22-2009   #7
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
rod knock.... ? arg....
http://www.youtube.com/watch?v=XX3ZXOtAgZ8
Old 10-22-2009   #8
caffeinetripp
DSM's Dead
caffeinetripp's Avatar
Drives: '91 Dakokta
Rod knock. Ick. FAIL. Like super mega ultra bad.
'92 MX-3 KLZE Swap, I/H/E, battery relocate.
caffeinetripp is offline   Reply With Quote
Old 10-22-2009   #9
way2fastalon
IS Broken :-/
way2fastalon's Avatar
that is the sound of the piston hitting the head i just had that noise on my engine ..
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 10-22-2009   #10
wow, mega rod knock. I wouldn't run it at all anymore till you rebuild the bottom end. At the very least, it's gonna need bearings. At the worst, a crank and whatever rod spun the bearing.
Old 10-23-2009   #11
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
I thought that it is related to the cylinder head as well.
Old 10-23-2009   #12
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
I can't believe it! WTF, I just got done piecing the bottom end back together and putting it back in the car. I didn't even take out the pistons and rods, as the compression was 175 across the board before dismantling it. I had the crank checked over by Crankshaft Supply.
I'll pull the oil pan this weekend and replace all the bearings. Are there any other things I should check while I'm at it?
Old 10-23-2009   #13
95talonracer
Finally Tuned...
Drives: Spyder GSX
Well if you pull the oil pan and there is a line of metallic shavings in line with the rods or mains then you have to take the crank out, get a new crank, check and possibly replace the rods, make sure the mains didnt spin and wreck the block, and then you can put it back together. Let us know what it ended up being.
Amsoil Dealer
Old 10-23-2009   #14
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
That's the thing... there wasn't any metal shavings in the oil pan the last time round. Everything LOOKED solid. But, we'll see...again...
