Old 11-06-2009   #1
allyoucaneat_talon
allyoucaneat_talon's Avatar
Drives: 93 Talon Tsi AWD
My new turbo neon.
Hello guys. I guess I went and picked up a turbo neon. Very nice and clean car. I think it share the same motor (420A) as the fwd newer dsm. Here's what it have.
It's a white 97 coupe with the dark grey cloth interior, 75k miles, fully built engine including;
-Engine
2.0 DOHC
JE pistons 8.5:1 +.20 bore
Eagle H-Beam rods
Mopar OEM bearings
ARP Rod bolts
ARP Head studs
Fel-Pro Permatorque head gasket
Melling oil pump
Ported and polished head
1mm oversized valves
3-angle valve job
SBI rocker/rollers and lifters
Crower valve springs
Crower stage 3 camshafts
Full wire tuck and fuse box relocation
Battery moved to trunk (securley mounted)
PCM Relocate.
-Turbo setup
Stock SRT-4 turbofold
Stock SRT-4 turbo
Stock SRT-4 wastegate
Stock SRT-4 FMIC painted black for the sleeper look
TurboX RFL blow off valve
-Transmission
Clutchmasters stage 4 clutch
Royal Purple Syncromax fluid
Freshly rebuilt transmission (new bearings and all)
Tappered open diff pin
-Suspension
Eibach Prosport springs
Koni shocks
Rear upper strut bar
Stock anti-sway bars
-Exhaust
Full turbo-back, non-restricted, mandrel bent 3" stainless pipe
Apexi n1 muffler, 3" straight through.
-Interior
Custom gauge cluster dual pod
Autometer sport-comp boost and pyrometer (EGT) gauges
AEM wideband
Super short throw shifter
Razo counter weight shift knob
Everything else is stock, and clean
-Exterior
Stock ACR wheels, painted black with polsihed lip
ACR front bumper cover with 95 Honda Civic lip
White eyelids
ID:	9402   Click image for larger version
ID:	9403   Click image for larger version
ID:	9405   Click image for larger version
ID:	9406   Click image for larger version
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-06-2009   #2
Re: My new turbo neon.
interesting
Old 11-06-2009   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
cute nhia...hahahahaha
Old 11-06-2009   #4
That thing would be mega sleeper if it wasn't for the huge exhaust can. Get a bigger turbo and supporting fuel system and start beating some ass. Otherwise, there's a turbo prism on mnsc that prolly wants a piece of that action :P
Old 11-06-2009   #5
twack
It was a auto get over it
twack's Avatar
is that the car that was running megasquirt from mankato?
Old 11-06-2009   #6
allyoucaneat_talon
No, I got this car from up north. Yea it's a sleeper, but when you stop at a stop light, you can totally tell that the car is not a sleeper with the stage 3 cams...
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-06-2009   #7
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
cool car, and yay for another 420a :-D
Old 11-06-2009   #8
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Interesting. Not really hot about the baby fuel injection system but I suppose its probably good for what its got.
It is a sleeper for sure.
I bet a 16g and some 750's would make it a wheel spin rocket. Heck, a 14b and some 550's would be sweet.
it's alive!!!
deadeye is offline   Reply With Quote
Old 11-07-2009   #9
allyoucaneat_talon
That's what I was thinking of. Well Let you guys now more about the plans.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-07-2009   #10
Keith H
Nice! That things the hawtness! Definitely agree with the above. Fuel system, bigger turbo, more boost! Do you mind me asking how much you got it for?
I'm in the middle of a full srt4 swap into a '96 coupe myself. I hope to have it running by spring.
Keith H is offline   Reply With Quote
Old 11-07-2009   #11
mdost03
Sonic Champion!
Drives: VA STI
Did you buy this from a guy named Brandon?
Old 11-07-2009   #12
allyoucaneat_talon
Yes I did get it from Brandon. Kool guy. It used to be a sohc turbo and he blow the motor and got the 420a motor and built it. How do you know him?
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-07-2009   #13
allyoucaneat_talon
I did a trade . The guy needed a 4dr car. If it wasn't a trade, he was asking $4000.00
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-07-2009   #14
mdost03
Sonic Champion!
Drives: VA STI
I've known him for a while, great guy and you should have a pretty solid car there.
Old 11-07-2009   #15
Didn't he say it already has a srt turbo? Aren't those small16g's?
Any dyno numbers?
Old 11-07-2009   #16
mdost03
Sonic Champion!
Drives: VA STI
I'm not exactly sure the specs on the stock SRT turbos, but they are very small haha.
Old 11-07-2009   #17
jrohner
jrohner's Avatar
That tiny toy turbo has got to be holding it back with stg3 cams and ported head, as are the injectors.
Old 11-07-2009   #18
Hmm... Seems like a lot of work to put into a Neon...
Old 11-07-2009   #19
allyoucaneat_talon
No dyno numbers yet. Hoping for this coming up spring. I'm just going to store it and find a beater. Yea srt-4 turbo are tiny compare to 16g. I think the max boost on it is 15psi. I lower the boost to only 8psi. Plan is to go 50trim with 750cc. But not sure yet. Still searching and reading on stuff about it.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 11-07-2009   #20
Isn't that what a rusty Neon is?
