Go Back   MitsuStyle > Hosted Support Forums > JET's Customs
Old 04-26-2004   #21
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Originally posted by JET@Oct 23 2003, 09:17 PM
Stage I head porting with valves out $80
Sorry, but is stage I a 3-angle, or what? May be interested...
Old 04-26-2004   #22
When someone says a 3 angle, that is the valve job. You can also get a 5 angle.
A level 1 port job cleans up all of the casting flaws, parting lines and smooths out the flow. I am not currently offering anything higher than a level 1 because I have not done the testing yet. I am doing a stage 3 head for myself that I will get before and after dyno results on. I would recommend the level 1 port job for someone between 350 whp - 450 whp.
Old 04-26-2004   #23
SuperSleeper
Gotcha. Just saw valves mentioned and started thinking you were doing valve jobs... my bad.
Old 05-03-2004   #24
SuperSleeper
Do you have a pic of any ported heads? I'm seriously considering it, and need to get it done soon. Doesn't require a whole lot of porting, but would definitely make a difference. Head is all disassembled and ready to go. Drop me a PM or something.
Old 07-15-2004   #25
Here is a 14b that I did for a member. The wastegate outlet is also ported, but I couldn't get a decent pic of that. It is so damn shiny that I couldn't get the camera to focus on it decent! I took about 20 pictures and these are the best.
Not too shabby for $50, eh?
Old 07-15-2004   #26
Another
Old 07-15-2004   #27
Exhaust outlet
Old 07-15-2004   #28
Bellmouth and polish of the compressor intake
Old 07-15-2004   #29
Lastly the compressor outlet
Old 07-15-2004   #30
IndiEP
Tha MIG Masta!
IndiEP's Avatar
:drool: Dude, you have outdone yourself!
Austin
Old 07-16-2004   #31
That yours Austin?
Old 07-17-2004   #32
Yes, that is Austin's 14b.
Here are some pic's of my head that I ported. It is pretty extreme on the exhaust side and there are about 15 hours of porting in the head.
Old 07-17-2004   #33
Another view
Old 07-17-2004   #34
It doesn't take much on the intake side, it is already pretty big.
Old 07-26-2004   #35
hey so is that the stage 1 head porting you offer? if not, how much for that right there? also wondering if you had any pictures of any 2g exhaust mani's you've done. Lastly, what about notching a 4g63 block to accept a 2.4 crank? Thanx and nice work on Austins turbo man.
Old 08-01-2004   #36
also wondering if you have any pics of exh mani's or O2 housings you've done. Those are what I'm gunna need done here soon, thanx.
Old 08-01-2004   #37
I have an O2 housing I am going to be doing in the next couple of days, I will take a pic when I am done.
That head is a stage 3 or 4 head, there is 16 hours of port work into it. The pictures don't do it justice at all. The exhaust ports are about 50% bigger than stock. That would be $325. It is pretty extreme though, I can do something in the middle for $200 also.
Old 08-01-2004   #38
Are you able to do full head rebuilds, similar to what Engintecs does out in Chicago: http://www.engintecs.com/html/dsm_heads.html ?
Old 08-01-2004   #39
I don't do any of the machine work myself. You can take it to your machine shop, or I can take it to one. There are several good machine shops around.
Old 08-11-2004   #40
Kougar
Drives: 06 RSX
Would it be an easy/cheap job to cut off my turbo flange and weld up a t3 flange? It's a quest manifold, trying to prep it for a 17c turbo (which would need a rebuild....you do them too?)
