Old 01-04-2010   #141
Re: 91 Galant VR4
For the engine dyno they have a Aeromotive Eliminator pump, which has supported a 427 with a F2R super charger making around 1000 crank HP on E-85, and 8 1600's running it. In the car I will go with a Fuel Lab pump of similar size, they have a built in voltage regulator.
Old 01-04-2010   #142
Re: 91 Galant VR4
F2R + 427 = :drool:
Old 01-04-2010   #143
Re: 91 Galant VR4
What Fuel Lab pump were you planning on? Sorry for all the questions, just its cool to see some one local go crazy on a build and I'm always trying to get new ideas.
Also curious because I guy on the link forums had a 42401 FueLab pump and he has had it fail twice on him already. Can't wait to see this thing in action.
Old 01-06-2010   #144
Re: 91 Galant VR4
Back on all 4, with the fenders just bolted back on with some original factory mounts.
A lot of gussets and a new steering wheel mount.
I added some material to the strut mounts.
I will have 3 injectors per runner. That is a custom 1 1/4" aluminum fuel rail, I just need to weld on some -10 AN fittings. The secondary fuel injectors are as high up the runner as they can be. They are mounted on the bottom to provide a little cleaner look to the engine bay.
Here is the finished exhaust manifold.
Here is the pipe bender converted to hydraulic power. It now uses a 2" cylinder with a 10" stroke to bend the pipe. This is a 12v DC hydraulic power supply so a car battery with a battery charger back up is used during bending. It will do a 30 deg bend in one stroke of the cylinder and the system is really quiet and works great. We decided to build another work bench along the west wall of the garage so we needed to eliminate the hand operated bending arm. I have a few more pics in my garage section of my photo gallery. http://www.mitsustyle.com/photopost/useralbums.php
Old 01-06-2010   #145
Forced Fed
Drives: FS-T
Re: 91 Galant VR4
Now that is what I call a fuel rail! Good call on mounting that beast on the bottom, would look a little clustered with 12 injectors...
Old 01-06-2010   #146
Re: 91 Galant VR4
is that going to clear the starter? or things like the alternator (if it's on the backside)? Either way, that's art! I'd put it up top!
Old 01-06-2010   #147
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: 91 Galant VR4
That manifold is nuts! Keep up the good work. Wouldn't mind having that pipe bender either lol.
Old 01-06-2010   #148
Re: 91 Galant VR4
Looks good John.
Old 01-06-2010   #149
Re: 91 Galant VR4
looking really good john
Old 01-06-2010   #150
Re: 91 Galant VR4
Fucking nice.
Old 01-06-2010   #151
Re: 91 Galant VR4
Wow, that thing is gonna be able to dump some fuel! Everything looks really nice so far.
Old 01-06-2010   #152
Re: 91 Galant VR4
Love the intake manifold, that is some crazy welding.
Old 01-06-2010   #153
Re: 91 Galant VR4
Looks good, I love tube frame anything.
Old 01-06-2010   #154
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Re: 91 Galant VR4
Yea he's a local guy, Both pumps were bought brand new and both failed on him within a few miles. Why not just go with the A1000 or the Eliminator pump? I know they need a voltage regulator, But one of those can be gotten cheap.
Looking good John, I want a ride when its finished...
Old 01-06-2010   #155
Re: 91 Galant VR4
Looks good, definitely keep updating the thread with pictures!
Old 01-08-2010   #156
Re: 91 Galant VR4
I will be going to discount steel tomorrow to pick up some aluminum square stock to make the frame to hold the front clip together. Right now the design will not have a hood that opens but pulling just 4 pins and a few zuss fasteners the front clip will slide of off 4 tube round tube pegs, then a multi pin connector for the head lights and turn signals. I try to post pics as needed, is there any parts of the car that I have not showed that you guys want to see?
Old 01-08-2010   #157
Re: 91 Galant VR4
I gt an idea to do that to car a while ago when I learned about those connectors, keep up the hard work there is a lot of us that can't wait to see it.
Old 01-09-2010   #158
Re: 91 Galant VR4
What are your plans for rear suspension? 4 link with a ford 9" or keep blowing up stock axles? haha
Old 01-09-2010   #159
Constant_Project21
Drives: E36
Re: 91 Galant VR4
Is the turbo in the IC mock up pictures, the one you're using?
Old 01-09-2010   #160
Re: 91 Galant VR4
Yes, its a journal bearing garrett GT 4202 with the 1.01 divided exhaust housing. This is the turbo I bought 6 years ago and it has about 20 miles on it.
