Old 01-07-2010   #1
DSM_brother2
Drives: to the shop
hx-40
where do i get a hx-40? what do you guys think of them?
93 talon tsi/ 6 bolt swap
Mitch
Old 01-07-2010   #2
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: hx-40
i have one of these pm me if interested
Old 01-07-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: hx-40
The only thing is oil pressure. You have to be VERY accurate with how much oil you're giving them. That is why a lot of people have problems with them.
Originally Posted by wheelhop View Post
This is your answer. Don't guess. DSMs kill SO many journal bearing garrett, BW, holset turbos. Because they are all more sensitive to oil changes and especially over oiling. And DSMs change their oil pressure per setup, rpm, motor build, oil pump age, Bshafts, oil pump years, oil cooling, hair part, shoe lace orientation, etc. FAR more than any other engine on the planet. PTE has a bad rep because of sh!tty DSM oiling problems. Its DSM oiling that sucks, not PTE (AKA garrett center sections). It's not the manufacturers fault. Its the haphazard, random oil pressures that dsms run on various setups.
Use any gauge: oil gauge, old fuel pressure gauge, old air compressor gauge, old water pressure gauge for home water feed lines, who cares. Get SOMETHING on there after the lines and restrictions to actually see what your oil pressure is. Rev the motor in neutral and find out the oil pressurea at idle, theoretical spool up rpm, and peak oil pressure (should be at redline). Per the holset repair manual for the hx35/hx40: Warmed up, the oil pressure for the hx35 and hx40 should be no less than 10psi at idle, and no more than 72 psi. It should be no less than 30psi at spooling time and after. A bolton hx35 sees 20psi at about 3700rpms and spools damn early so you had better have 30 psi at 2K or you could be eating turbo bearings. An bolton hx40 sess 20 psi as early as 4K on a 2.0L motor. Check your oil pressure. As stated, you MUST have 30psi during spooling up conditions with these turbos. And you cannot have more than 72 psi pressure at full song.
Best post ever made for anyone looking to buy a holset!
-1990 Mitsubishi Cyborg 4WD-
Old 01-07-2010   #4
DSM_brother2
Drives: to the shop
Re: hx-40
sweet! thanks good to kno!
Mitch
Old 01-07-2010   #5
jrohner
jrohner's Avatar
Re: hx-40
I've gotten two H1C's on ebay for great deals and they're both sweet. There are always HX40/H1E's on there as well.
Old 01-07-2010   #6
Re: hx-40
How much power are you trying to make? HX40 is pretty big.
(side note: doesn't anyone enjoy modding there cars slow anymore, or does everyone just want to go faster than the next guy)
Old 01-08-2010   #7
CarPsyco84
CarPsyco84's Avatar
Re: hx-40
Comeon, we all know size matters
-When in doubt, Moar RPM.
Old 01-08-2010   #8
jrohner
jrohner's Avatar
Re: hx-40
There are many different versions of the HX40. The best ones are good for nearly 700hp in a bolton housing, and the worst ones are close to the same hp wise as an HX35.
There are 6,7,8 blade compressors, and 10 & 12 blade turbines. Some compressors are bigger than others as well. The 12 blade turbine is for the highest hp, and the 6 & 7 blade compressors are supposed to be much better than the 8 blade ones.
HX35's are a lot simpler, since the two main ones are 7 blade compressor and 8 blade compressor. The 7 blade flows more so it's a better match for a larger T3 turbine housing, and the 8 blade matches up very well with the small bolton housing.
Old 01-08-2010   #9
Re: hx-40
Kevin has an HX40 on his 1G. http://www.mitsustyle.com/forums/showthread.php?t=18991
Old 01-08-2010   #10
jrohner
jrohner's Avatar
Re: hx-40
That car is nice, I remember seeing it at the cookout. I was quite interested in looking at it since it was the first one I got to look at with a Holset on it.
Now I have a 91 GSX auto that I'm running a Holset H1C (bolton) on with no intercooler. I like the Holset so much already that I bought another one for my white car.
Old 01-08-2010   #11
Re: hx-40
I have the HX35 bolton, but I plan on going T3 in may with it.
Old 01-08-2010   #12
DSM_brother2
Drives: to the shop
Re: hx-40
im really hoping for 450 hp, and i have a small 16g turbo, with alot of supporting mods already. i just seen that the hx-40 turbo seems good
Mitch
Old 01-09-2010   #13
jrohner
jrohner's Avatar
Re: hx-40
If you're going for 450 on a dynojet, the HX35 should do it pretty easily with good fuel. 450 on a dyno dynamics however...?
Old 01-10-2010   #14
DSM_brother2
Drives: to the shop
Re: hx-40
not sure yet, are the holset bolt ons? or do i need kits?
Mitch
Old 01-11-2010   #15
jrohner
jrohner's Avatar
Re: hx-40
For a direct DSM bolton, you need the bolton turbine housing from Bullseye Performance. It seems like they have again became hard to find though. Look up G-Pop Shop, they might have some.
Old 01-11-2010   #16
Re: hx-40
I have been very happy with my turbo (6 blade comp, 12 blade exhaust HX40), , other than having 2 brand new ones fail me.
Old 01-11-2010   #17
Re: hx-40
What's the deal with that anyways? This is a HUGE turn-off for me, and I'd think for anyone else even remotely interested in these things. Oil pressure issues or what?
Old 01-11-2010   #18
Re: hx-40
Tim's Turbo's might be another place you want to try out.
http://www.timsturbos.com/products.html
