Old 01-13-2010   #101
Re: Yep..another one.
I threw an EvoIII 16g on my car last spring and decided to keep the external wastegate run off the o2 housing the same way I had my GT3076 set up. I'm planning on bringing it to Shane this spring for a tune on E-fuel so I'll see what I can wring it out for. I'm hoping for anywhere between 375 and 40, and as much boost as the turbo can handle and still be somewhat efficient.
Old 01-13-2010   #102
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
What numbers did you see with the big 16g at that level? Idk if I'll push the evo 3 16g that far, but would be nice to have an idea. And def let me know when you sell those injectors.
I never really did get a clean dyno session in. But at MAP I put down 370whp on the small 16g. Still not on the best of a tune do to a failing bov.
-1990 Mitsubishi Cyborg 4WD-
Old 01-13-2010   #103
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I haven't decided whether to go with an external wastegate set up or not. I'm not trying to get a ton on my plate, cause the more that gets added to my list, less likely I have money to do it.
Also have to ask where you got your headlights (kevin1gdrummer), I know it's OT, so if you could just pm me with where ya got um, or just reply to the thread I made. Mark had said something about you having blackhousings, and I'm looking for a set.
Old 01-13-2010   #104
Constant_Project21
Drives: E36
Thats promising, I hope to have numbers like that at db on an evo 3 16g.
Old 01-13-2010   #105
Those are also FWD numbers...
95tsi on here has a 2.3 stroker, 272's, SMIM, E-85, FMIC, pretty much the works, and makes 347hp and 361tq @ DB Just for a comparison
Old 01-13-2010   #106
Constant_Project21
Drives: E36
I know they're fwd numbers, and thats also at MAP on a small 16g. I'm not looking for giant numbers. Honestly 300+hp at db is more than fine with me. I'm not out to make a horsepower monster, just a fun street car, that I can take to the track everyonce in a while.
Old 01-17-2010   #107
Constant_Project21
Drives: E36
Hmm...so as I stated earlier in this thread, if the right deal on a bigger turbo came along..that I'd go bigger. Well, I got a deal I couldn't in my right mind pass up. Ill post up some pics when I get it, just sent my paypal payment
Old 01-20-2010   #108
Constant_Project21
Drives: E36
So my new turbo got sent out yesterday. Bought it needing a rebuild, so got it dirt cheap. It's an PTE scm6152e, set up for an external gate. So I'm heading in quite a different direction. I'm not dead set on using it, and since my car isn't gonna get touched until spring, I got some time to mull it over. Ordering a set of super low mile Rc 1200cc injectors (again, no way I'm paying full price haha) tomorrow, or Friday. Gonna be ditching the safc as well, and I'm still waiting to find out when ecmlink lite is coming out. Once that's out, I'll swoop that up. Have an EPROM somewhere (hopefully, recently went missing), so well on my way to the set up I want.
Best part is, haven't really spent any money so far. Parts I've been getting rid of, have managed to fund all the new stuff. So I'm keeping with my budget build goal. Still need to find some 3kgt vr4 brackets for the 1g...*cough chim55117 cough*.
Old 01-21-2010   #109
You should just have Shane burn you a chip with the Eprom if you're working on a bit of a budget. I'm probably going to go with an Evo 8 ECU, just have to find someone to make a harness for me...
Old 01-21-2010   #110
Constant_Project21
Drives: E36
I didn't really have a good experience with the last chip I had used. I had one for my 560's and 16g, and my car just didn't seem to run right (used a maf-t as well). Idk couldve been something else wrong with the car, guess I could give it a shot.
Ecmlink lite is like $325, which doesn't hurt my feelings too bad. Either way shane will do some sort of tune.
Old 01-21-2010   #111
^^Shane will burn the chip custom to your setup though dude. Really not any different than Link, just that you can't really make adjustments to it without buying an emulator/chip burner/etc.
Old 01-21-2010   #112
Constant_Project21
Drives: E36
I'll have to give them a call before I go out and buy link then. I don't feel the need to make adjustments on the fly, because hopefully once I have this all put back together, I won't have to worry about changing stuff up. I'm trying to make it somewhat reliable, which is making me rethink the big turbo route. But I don't see why it can't be reliable, as long as I take my time, and do everything right. I'm not in a huge rush to drive it, more excited to work on it. Gets my mind off crap haha.
Old 01-21-2010   #113
Constant_Project21
Drives: E36
So I just bought a set of FIC 1150cc injectors for $100 brand new in the box. Am I gonna be pushing these pretty hard with my scm61, or should I be fine with those? I'm buying them either way, if I need to go bigger, then I'll just sell them, and get bigger ones.
Old 01-21-2010   #114
mlomker
*Resting In Peace*
mlomker's Avatar
Some guys prefer big turbos since they're out of boost more and give you better gas mileage. Not sure how big an scm61 is. I know that you'll run out of single Walbro before you do 1150 injectors. Is that turbo over 450 at DB?
Old 01-21-2010   #115
I believe 1150s should about max out a single 255lph pump. So you'll be pushing both the pump and injectors probably, if you're going for over 400whp.
Old 01-21-2010   #116
Constant_Project21
Drives: E36
I'll be looking for ~400hp out of the turbo. I guess I'll pick then up, and just sell them, and look to get some bigger ones, and look into different fuel pump options. I didn't even think about maxxing the pump out. The turbo (I believe) is rated at 350-630hp, I think that's what I read a while back.
Old 01-21-2010   #117
You'll be fine with your setup at 400whp. I think most people start maxing out the pump around 440whp at DB.
Old 01-21-2010   #118
Constant_Project21
Drives: E36
I haven't settled on a goal, which is not the way to head into a project, I know that haha. I don't wanna get stuck maxing out parts, cause that's when they end up failing. I would be ecstatic with a 425hp street car, but need reliability to be part of that as well. Have to keep reading up on stuff lol.
Old 01-21-2010   #119
mlomker
*Resting In Peace*
mlomker's Avatar
The cost to beef everything up pretty much doubles somewhere in the 400's. Shooting for >450 at DB is an investment.
Old 01-21-2010   #120
Constant_Project21
Drives: E36
Yea which makes me wanna not go higher then 400. I'm not planning on driving this car, until it's the way I want it, and so it's to the point where I'm not wrecking stuff every month. Getting an ugly, but reliable, 91 sentra to cruise around in, in the meantime.
