Old 01-27-2010   #1
Why Can't I Launch Well?
I don't know if this is the place for this but, please help me figure out why I can't launch my 1G AWD well.
With my last 1G AWD, like 250hp(lol) stock suspension, ACT2600 street, 225/45/17 KDWs. I'd rev up to like 6k rpm, and dump/slip the clutch. Spin 4 tires and haul.
Curent car: A LOT more power, DSMLink, Ksport coilovers, 225/45/17 KDWs, ACT2600 w/6puck. I hit the launch control, and then slip/dump clutch. and then No Lift To Shift. I think when I slip the clutch I'm taking my foot off the gas which is messing up the NLTS function. Make sense? So then I hit the NLTS rev limit in 1st gear. Its effed up. Oh and I can't spin my tires at all. Wtf? It just doesn't happen. I know that sounds ricery, but...
bets 60ft was 1.7 but I mostly have like 1.9s and 1.8s and 2.0s lol
I'm probably a shitty driver.
Old 01-27-2010   #2
Re: Why Can't I Launch Well?
What boost are you leaving at before vs. now?
Old 01-27-2010   #3
Aren't bigger turbos a lot harder to launch correctly? It could be you just have to relearn on this setup.
Old 01-27-2010   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Yeah you just need some more practice. More power is a lot harder to handle when launching. Eventually you'll figure out the sweet spot.
-1990 Mitsubishi Cyborg 4WD-
Old 01-27-2010   #5
I'm sure you had a lot more boost built up at launch before, and thus more torque when you dumped the clutch? Just practice a bunch of different things and you'll be good.
Old 01-27-2010   #6
If you had a 14B or 16G before, then that might be why. It's way easier to launch a small turbo car.
Old 01-27-2010   #7
blageo23
AWD4G64
blageo23's Avatar
He had a 20G on it before. And Ive been in the car on a launch and it was crazy. with his current set up it honestly feels like hes just pulling away from a stop sign. Somethings not right.
1998 Spyder AWD
567hp
490tq
Old 01-27-2010   #8
How much boost are you building at the line? I take it you have the anti lag enabled?
Are you bogging on the launch or does it not feel as strong?
Old 01-27-2010   #9
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Can i launch it for you?
'04 Honda Ricer: stock
Old 01-27-2010   #10
A 20G is a small turbo though too, they spool great compared to a what he has. Maybe he needs to launch at a higher RPM. A big turbo isn't going to be spooled until past 6000 RPMs in first gear. The dump the clutch and spin the tires stuff doesn't work so good with bigger power cars. If you do spin them, it will probably instantly goto revlimiter and screw you that way.
Old 01-27-2010   #11
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Yea the bigger turbo prob makes the difference. My shitty 16g talon had almost the same 60fts as you, it would rip (kinda) off a launch, then the rest of the ride was rather mundane. I'll have to re-learn how to drive my car this summer with the scm61 on there. Practice makes perfect kevin lol.
Old 01-27-2010   #12
Sounds like you're dumping it a little too much, at least to me. Does it feel like it bog really bad and then takes off? Maybe upping the launch rpm and trying to slip the clutch more will do the trick.
Practice does make perfect though, hell I suck at launching too. haha
Old 01-27-2010   #13
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
does it pull like when I gave you and mike a ride when I launched my eclipse? I have my launch set at 6250 and just slip the clutch a little more.
Amsoil Dealer
Old 01-27-2010   #14
mike55112
mike55112's Avatar
Drives: 04 evo
I used to spin through first with both the HTA88 and 40R and I was at similar power but lots more torque. Have you tried launching without the NLTS
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 01-28-2010   #15
jrohner
jrohner's Avatar
I can launch great just holding the RPMs at 4 grand, but if I use a 2-step rev limiter, I can't do crap no matter what, even at a much higher RPM.
Old 01-29-2010   #16
CarPsyco84
CarPsyco84's Avatar
is it building boost before you launch? If not then it needs more... more rpm or more build time I would guess.
-When in doubt, Moar RPM.
