Old 01-28-2010   #1
travail
travail's Avatar
Drives: EV0 8
oil catch can install
What is the best way to install one on a evo.
travail is offline   Reply With Quote
Old 01-28-2010   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: oil catch can install
Is it not the same as DSM's?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 01-28-2010   #3
travail
travail's Avatar
Drives: EV0 8
I have never installed one so I don't know.
Old 01-28-2010   #4
123abc
123abc's Avatar
Drives: Loud cars
The way I did mine deletes the pcv valve. Just screw a nipple into it's place, run a hose from that and the other valve cover breather port to the catch can. Then have a seperate hose come in through the top of your can and go to your intake pipe.
I'm on a blow-through setup though, so I don't know how this would apply to you.
Old 01-28-2010   #5
travail
travail's Avatar
Drives: EV0 8
so like this
Old 01-28-2010   #6
mlomker
*Resting In Peace*
mlomker's Avatar
Interesting. On the X the stock line runs from the valve cover to the intake. When I install my AMS intake (which doesn't come with the inlet) I was just going to run the line to the catch can. I didn't think there was a need for an outlet on the catch can. Need to research that.
Old 01-28-2010   #7
Ideally you're going to want 2 catch-cans for a proper install and to maintain vacuum inside your crankcase.
VC breather ---> MAP crankcase vent (optional but recomended) ---> catch can ---> intake pipe
AND
stock PCV ---> catch can ---> MAP crankcase vent ---> intake manifold
http://www.maperformance.com/map-cra...acuum-kit.html
Old 01-28-2010   #8
travail
travail's Avatar
Drives: EV0 8
AND
You really need two of them.
Old 01-28-2010   #9
If you want to route both the breather and PCV to a can then yes, you need 2. If you do just one can though then pick which of the above two is more important to you and go that route. I personally have 1 can setup between the VC breather and intake pipe.
Old 01-28-2010   #10
123abc
123abc's Avatar
Drives: Loud cars
Originally Posted by travail View Post
so like this
Yes except you have the line going to the intake manifold, not where the pcv valve use to screw into the vc.
Old 01-28-2010   #11
Doing that, without any check-valves, is a terrible idea since you'll be pressurizing the catch-can AND crankcase during on-boost conditions!
Old 01-28-2010   #12
123abc
123abc's Avatar
Drives: Loud cars
There's no pressure in there, only vaccum. I have the 3rd tube going to the intake pipe, before the turbo with an inline filter.
Old 01-28-2010   #13
How is there no pressure when you have a line run directly from the intake manifold?
Old 01-28-2010   #14
123abc
123abc's Avatar
Drives: Loud cars
I meant to say he did it wrong, that line gets ran to the VC. I keep thinking DSM's where the pcv valve goes to the vc. Obviously that won't work hooked up to the intake manifold.
Old 01-28-2010   #15
Evos and DSMs have their VC breathers and PCV valves setup in the same way, just in different locations.
Old 01-28-2010   #16
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Do you have a pic of it under your hood?
Old 01-28-2010   #17
Why not have both the VC outlets go into the intake pipe? The PCV going into the intake mani is pressurized under boost so it does nothing. If they both go into the intake pipe the turbo will be sucking air out from both VC locations at all times. Granted this will probably look messier, but oh well.
Old 01-28-2010   #18
And all that blow by going into the turbo? no thanks.
Old 01-28-2010   #19
123abc
123abc's Avatar
Drives: Loud cars
The 2 red hoses go to my catch can. Then the green hose goes to my intake tube. No pressure, only vacuum.
Thats the point of a catch can dude, to catch the shit and suck out vapors. It's a better way of doing the same thing the factory did in my opinion.
Old 01-28-2010   #20
This. Just run both VC vents into a single catch can and then to the intake pipe.
