Old 02-05-2010   #241
Re: Swifty's never-ending project thread!
Well, I was waiting to post anything up, but scheides kinda forced the hand.
Whatever punk, you mentioned UPS coming with your new turbo in the shoutbox multiple times, then were talking about it, blah blah blah....don't try so hard to pretend to be a wallflower when you know you're an attention-whore :P
Old 02-05-2010   #242
Did you ever figure out the reving issue?
Thats a pretty cool turbo tho, hope you put it to good use!
Old 02-05-2010   #243
The 67 didn't want to spool on your car...like it does on other DSMs. Two words: hello lag.
Hello 1000RPM of usable powerband.
Old 02-05-2010   #244
mlomker
*Resting In Peace*
mlomker's Avatar
I assume he's building the head for 9k rpm or somesuch.
Old 02-05-2010   #245
Yea I dunno, big turbos are cool. But I would have stuck the money into fixing the ignition issues, and maybe a paint job.
I like having power for more than 2k rpm too. Just doesnt seem fun.
Old 02-05-2010   #246
Even then I bet he has less than 3000 RPM of usable power, and as of right now he can't even get the car to rev past 8000.
Low end power is for pussies.
Old 02-05-2010   #247
For drag racing he might need 2k of power.
Old 02-05-2010   #248
If you read back through this thread, this car has been plagued with a solid rev limit of like 7949rpm or something exact and he hasn't really been able to figure it out. I say put a hta68 on it and you have the perfect street car/drag brawler.
Old 02-05-2010   #249
But hes never drag raced. haha
Old 02-05-2010   #250
Old 02-05-2010   #251
We think the rev limiter issue has been fixed, as everything else has been looked over, ohmd, tested, etc. The valvesprings couldn't keep up with my cams, especially since they where not properly shimmed, but rather thrown into the head, like most of us would do.
Lag. I don't really care. I like the fact that it's laggy, in all honesty. Regular driving, the car is easy, like a honda, and when I want power, just downshift. You all act like it's soooo hard to find the powerband and drive in it.
Small ass turbos don't make the power I wish for. Plain and Simple. Who knows when I'll stop, but right now I am still working things out.
For a second there, I thought I was reading another swifty bashing thread, not a BUILD/PROJECT thread...
Old 02-05-2010   #252
Originally Posted by swifty1638 View Post
lag. I don't really care. I like the fact that it's laggy, in all honesty. Regular driving, the car is easy, like a honda, and when i want power, just downshift. You all act like it's soooo hard to find the powerband and drive in it.
Small ass turbos don't make the power i wish for. Plain and simple. Who knows when i'll stop, but right now i am still working things out.
truf.
Old 02-05-2010   #253
You seem to constantly be working things out. When was the last time you stuck with a setup long enough to even attempt to achieve the maximum potential of that setup? Not hating, just calling it as I see it. You're kind of like a dog chasing a car, but you never catch the car because you start chasing another car that just passed you going the opposite direction.
Old 02-05-2010   #254
Please don't try to involve, group the rest of us in your failures. Most of us are not wanna be cool asshats.
Old 02-05-2010   #255
huh? I said not many people measure, check, and shim their valvesprings? Did you?
Old 02-05-2010   #256
We do on all the valvesprings and valves we do on heads, unless someone really wants them thrown in ghetto/internetz style without removing the head.
Old 02-05-2010   #257
Well then, I'm just a fuckup, and caused all my failures. I certainly HOPE this is the case! I know some springs/retainers you can throw in and not shim, other softer, or less strong ones you don't need to. The new ones I'm getting you don't need to.
Old 02-05-2010   #258
If you aren't throwing a mild spring into a 100% stock head, then you should probably have the installed height, seat pressure, coil bind, retainer to valve guide seal clearance, etc checked. Having different valves or a valve job can throw things off.
Old 02-05-2010   #259
Well, what about what I AM doing? 1mm oversized, otherwise stock porting, soda blasted so it's fresh and clean, and rau's beehive ferrera valvesprings, retainers, etc? He said he never shims his and doesn't have issues hitting 11,500rpms..I would hope i'd be ok to hit 9200?
Old 02-05-2010   #260
mlomker
*Resting In Peace*
mlomker's Avatar
How often does he tear down the motor? When you cross the line from daily driver (perhaps a 10 sec car) into these beastly ranges then I'm sure a lot of things are done differently.
